Old 09-09-2010
QuickMick's Avatar
QuickMick is on a distinguished road
Tiller Resto
While I have a pedestal system, there is an emergency back up tiller as well. After I took it out of the lazz i found it was becoming delaminated and weathered so decided to fix er up.
A few questions:
1. Is ye ole elmers wood glue ok, or should i use something else?
2. I found that the metal connecting deal is heavy so im thinking its nickel plated brass? what is the best way to clean this up w/o damaging it?
3. I was also thinking of drilling through it in a couple of places to add a couple of carrige bolts for added strength...yes/no?
thanks guys
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 09-09-2010
A few questions:
Use epoxy... it is better than wood glue IMHO and more water impermeable, etc.
Doubt it is brass if it is marine use gear...it is probably bronze... big difference. A good metal polish should clean it up. Miracle cloth works pretty well too..
Not a bad idea, but remember to epoxy coat the holes so that water can't get into the wood there.
In fact, I would highly recommend stripping the tiller down to bare wood, epoxying it back together and then coating it with CPES or some other penetrating epoxy to seal it...then re-varnishing it... to protect the epoxy from UV. Then put the hardware back on.
Oh Joy Resto 01/27/10 CharlieCobra Gear & Maintenance 14 01-29-2010 02:11 AM
Oh Joy resto 12/26/09 CharlieCobra Gear & Maintenance 4 12-28-2009 09:33 PM
Oh Joy resto 12/16/09 CharlieCobra Gear & Maintenance 15 12-17-2009 11:38 AM
Oh Joy resto 11/24/09 CharlieCobra Gear & Maintenance 14 11-25-2009 08:00 AM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
