09-09-2010
Another option, but a bit more labor intensive, is to seal up the cabin completely, and use a temporary drop board made of plywood and with a hole cut into it... put a leaf blower or big shop vac hose into the hole and duct tape around it... and fire it up.. .coat the deck and topsides with soapy water and look for bubbles... The air will come out the leaks... and the leaks may not be anywhere near where you expect them to be.
