fiberglass ding - SailNet Community
post #1 of 6 Old 09-09-2010 Thread Starter
QuickMick's Avatar
fiberglass ding
while redoing the interior of the cabin i pulled out all that awful fuzzy fabric stuff on the hull to make it more spiffy. anyway, after the stuff was out, i noticed a few spots in the glass where a lot more light is coming in. i can only think that the PO banged into something. while not holed, im concerened that this should be shored up, but dont know the best way to do it. can i just lay up some glass on the inside of the boat? it would be infinitely eaiser than doing it from the outside, but i wanna do it right. the pic is an example of one i found in the quarter b. sorry its so dark... el telephono no flasho...
thanks
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #2 of 6 Old 09-09-2010
Without better photos it is hard to say what the issue is. It could be something as simple as the gelcoat was thinner at that spot or that there was a hole drilled there and then just quickly patched over... or any other number of reasons there is some variance in the hull light transmission. Have you inspected the hull at that point??
sailingdog is offline
post #3 of 6 Old 09-09-2010 Thread Starter
QuickMick's Avatar
ill check tonight, and get a photo that doesnt stink. IIRC, there is no noticable blemish on the outside, so you very well may be right about simple inconsistency in the materials.
Quinn McColly
Macgregor Venture
post #4 of 6 Old 09-09-2010
Iroquois MkII
The little dots look like holes for old hardware filled with thickened epoxy. I just made some of those little dots in my boat last weekend...
LookingForCruiser is offline
post #5 of 6 Old 09-09-2010
mitiempo's Avatar
I don't think it is a problem unless the outside shows damage. With the liner off on my hull I can see the same in many places and my hull has not been damaged and the white gelcoat is intact. Except for the gelcoat fiberglas is very translucent.
Brian
mitiempo is online now
post #6 of 6 Old 09-09-2010
Underwater Basket Weaver
TintedChrome's Avatar
I had similar issues and moment of panic when I looked up towards the deck and forward towards the bow through the anchor locker a couple of weeks back (it's accessed in the v-berth).
I went outside and had my girlfriend inside guiding me to the "light" spots.. no difference in strength or mushiness compared to the rest of the hull and deck so I've chalked it up to thin gelcoat like sailingdog suggested.
I wouldn't be too worried unless it's apparent the location was a patch job.
s/v Tinou
1976 Northstar Farr 727
Hull #37
I can't imagine mastering the skills involved here without a clearer understanding of who's going to be impressed.
TintedChrome is offline
Teak & Holly Sole Ding Repair factfind Gear & Maintenance 6 05-19-2008 11:15 AM
Fiberglass - what do you think? brak Gear & Maintenance 12 07-17-2007 02:05 PM
Satire: I Be The King, Ring a' Ding Ding (Blogcritics.org) NewsReader News Feeds 0 09-25-2006 03:15 AM
Cutting fiberglass aruggiero Announcements and Suggestions Box 3 07-19-2006 01:18 PM
Steel or Fiberglass Mark Matthews Buying a Boat Articles 0 10-21-2000 09:00 PM
