Sails - SailNet Community
post #1 of 3 Old 04-23-2003 Thread Starter
Sails
We are neophyte sailers and are attempting to figure out what is wrong with our mainsail setup. We have a 1988 MacGregor26 (no idea of the age of the sails). The sail appears "wrinkled" on the mast side. We pull the line as far up as it will go and the sail itself is still about 5" short of the top of the mast. When examined, the sail material is slightly gathered along the rope inside the sail. Could the line itself have shrunken over time? I appreciate any help.
farmcrab is offline
post #2 of 3 Old 04-23-2003
DelmarRey's Avatar
Sails
Sounds to me like a stretched out sail. Does it have a belly at the foot too?
DelmarRey is offline
post #3 of 3 Old 04-24-2003
Sails
The fact that the head of the mainsail is 5 inches below the masthead is not necessarily any cause for concern. It sounds like you are describing horizontal wrinkles in the luff, which would mean the sail is not hauled up as much as it should be.
I would securely attach a light line to the main halyard shackle, then haul the halyard (without the sail) up to the masthead. Does it still stop in the same spot as when hoisting the main? If yes, then you need to investigate why. If it goes up to the top, then something is not allowing the main to be hoisted up the last few inches it needs to be. Since you apparently have a simple boltrope setup, I''m not sure what that could be.
DelmarRey''s suggestion might be the answer. Good luck.
Duane
DuaneIsing is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
