09-10-2010
Anchorsmith
This is a Spade:
New Generation Anchors
I don't know of any real close knock-offs, except the Turkish "Ultra" which looks quite different.
The Spade has a concave fluke and is nothing like a Delta which is a plow.
They are painted yellow on the topside of the fluke so that set depth can be judged from the surface. The paint typically doesn't last long though.
Now, if you are mistaking a Spade for a plow, and the paint may be on the wrong side, it seems to me there's a good chance that some idiot has assembled the thing wrongly (with the fluke upside-down). There have been a few cases referenced online where that has happened, with the owners in question even getting the mounting box modified because "it didn't fit together right". Check it looks like the pic above.
The Spade is a good primary, there's not even a contest between it and the Fortress. You shouldn't use a Danforth style as a primary at all.
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
