09-11-2010
Originally Posted by davidpm
The Tanzer 26 I was on yesterday had the standard two levers, one for transmission and one for throttle. It did not have a shutoff lever however. The owner just shut it off by pulling the throttle back just a little past idle. There was no way to know you were at idle however. No extra resistance. It was really easy to shut down the engine by mistake or shift at too high a speed.
Is their something missing that makes this engine easier to use. Seems like a particularly evil design.
I have same two lever design on my yanmar 2qm15. There is an idle control stopper, located on the engine, where the cable coming to. Cable should be adjusted in such way that it wont shut down the engine until pulled all way down. I mean that there is some sort of lug, some distance in lever's travel between idle speed and shut down position. Also cable tensioners are available at marine/auto stores. It is very simple device -sort of clamp with tension bolt. It goes around a cable in any place you like and it just makes travel of the cable inside of its jacket more difficult and, as result, it gives more resistance on controls.
Overall I have no problem what so ever with two levers, as soon as got used to it.
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
