09-13-2010
IIRC, the outboard well on the CD25 is about 8" x 12". Most four-stroke engines are going to have trouble with a well that small, and few will turn. The 8 HP you've got is about the largest four-stroke that will fit.
The head on the 9.8 Tohatsu four-stroke, according to this year's model dimensions is 14.4" wide... so I doubt it will fit, much less turn. The four-stroke engines are typically much larger than their two-stroke counterparts, and much heavier. The CD25 outboard well was designed with a two-stroke motor in mind.
