Originally Posted by AuntB
I would like peoples thoughts a Sea Sprite 23.
We are looking for our first sailboat. Over time I have adjusted from looking for an around the world boat to a smaller daysailer that would help me learn and improve my skills. We will be sailing in the Chesapeake Bay.
Today I looked at a 1967 Sea Sprite 23. Lovely lines, 3 year old North Sails, roller furling jib, solid hull. The standing and running rigging seems fine, anchor and rode in place, small outboard, and other misc equipment was there.
The down side:
1. One of the two stringers below the mast was flexed at some time in the past, the fiberglass is cracked. The issue was repaired with a small SS metal plate and was screwed into the stringer with 8 SS screws. Seems solid now.
This is not the proper way to repair a cracked fiberglass stringer, and is likely to fail regardless of how solid it appears. The stainless steel plate will likely cause stress risers along the stringer where it ends. This is why fiberglass repairs are generally tapered at a 12:1 ratio, to spread the stress along the laminate evenly.
2. A 1 to 2 square foot patch of deck on the port side near the mast sounds a bit different and maybe soft or it could just be the nonskid.
I doubt it...probably water intrusion into the laminate from the chainplates or the mast step/partners.
3. Both the starboard and port combings had attached cleats that pulled out and left quarter size holes surrounded by soft wood. There is a larger block of rotted teak at the aft of the combing that ties the combing to the deck.
The coamings are likely neglected and in need of replacement.
4. The hull is solid but has a square foot of damage where the boat rubbed on a piling. The damage goes below the gel coat.
How long has this damage been there. Water can enter the laminate if it isn't sealed and protected by gelcoat or other finish.
5. The hull, deck, and cabin needs scrubbing and paint.
Sounds like the boat was neglected.
6. No battery and the electric system has been removed. The lights remain in place.
Probably needs a complete rewiring job.
7. It rained today and there was moisture below the cushions under the hatch but very little water in the bilge. No bilge pump.
Sounds like it has some leaks. These can be a PITA to track down, as water can migrate a long way from the actual point of entry.
8. Several other smaller items also need attention.
I am handy but want to spend my time sailing not working. Does this list seem like a lot of time and/or a lot of money? Would this be a good first boat for the Bay?
Not sure a survey is needed on an inexpensive boat, but I will find someone to look at it before making a decision to purchase. Just wanted to get some ideas first.
If you want to sail, then pass on this boat, as it has some potentially serious issues.
I'd also recommend you read the
Boat Inspection Trip Tips thread I started, as it will help you determine whether any boats you look at are even worth going forward on, saving you the price of a survey on boats that aren't worth looking at further.
