volvo md2b raw water cooled - SailNet Community
post #1 of 7 Old 04-24-2003 Thread Starter
Anyone know what the life span is for a raw water cooled volvo md2b engine?
fsmith is offline
post #2 of 7 Old 04-25-2003
Mine is over 20 years and runs great,although I flush it with fresh water after every use.
Dave R.
windancer1 is offline
post #3 of 7 Old 04-25-2003
How do you go about flushing it with fresh? Also, how steady should the exhaust water be? Is there a specific volume? If it falls below a certain level does that indicate an impeller needs replacing?
sneuman is offline
post #4 of 7 Old 04-26-2003
sneuman,
I have a 5gal. tank that I keep filled with fresh water with a intake line running to a 3/4" two way valve that can select from either seawater or the tank. This has worked fine with no problems. Even the thermostat stays clean. I have a good size raw water strainer installed right after the seacock. I still replace the waterpump impeller and seals every year. The flow out the exh. should be constant,with a gush of water every 3 seconds or so.
Dave R.
post #5 of 7 Old 04-27-2003
that sounds like a good arrangement. btw, how much water should i see dumping out of the exhaust outlet. Now I''m getting cyclical spurts, but I think perhaps it should me more: if so, should i assume that''s a bad empeller?
sneuman is offline
post #6 of 7 Old 04-28-2003
My MD2B is 33 years old. When I first started running it, I was wondering why so little exhaust water. The intake is only 5/8", so how much can you really build up? It''s been fine for years with just a little cyclical spray - spurt. I replace the impeller annually, but the problems is often finding the paper gasket necessary for the pump cover. KW
VIEXILE is offline
post #7 of 7 Old 04-28-2003
My experience with the MD-2 was that I should be able to touch the exhaust water with my bare hands without it burning. It might be hot but not steaming or scalding. One or two spurts every 3-4 secs or so. If your temp gauge is about 155-165 for rwc you''re probably OK.
fourknots is offline
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 207 06-22-2015 03:38 PM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
Volvo 2001 Water Heater pmccann Cruising & Liveaboard Forum 1 03-02-2001 03:22 AM
