good deal on solar? - SailNet Community
post #1 of 21 Old 09-13-2010 Thread Starter
QuickMick's Avatar
good deal on solar?
ive got an advert with a 149.99 price on this
45 Watt Solar Panel Kit
with an additional 20% off... no inverter... is this reasonably priced/does it look like a good cantidate for a foray into the solar realm?
thanks
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #2 of 21 Old 09-13-2010
Yes, that's a pretty good deal. I've got one of the Chicago Electric panels, a 30 watt, that I use for winter charging of my batteries. Its been pretty reliable, even though it is exposed to salt water and such. However, I have a single panel, rather than the three smaller panels you'll have. Mounting them might be an issue.
You'll want to get some 3/8" cable loom to protect the wiring from UV damage.
BTW, solar panels don't need an inverter... Depending on the size of your battery bank, you may need a charge controller.
BTW, a 45 watt panel will probably yield about 15 amp-hours of battery charging per day on average. This is based on 3 amps at 14.4 volts times five hours of full output on average per day.
sailingdog is offline
post #3 of 21 Old 09-13-2010
mattstamour's Avatar
15 Watt Solar Battery Charger Kit - 8500020 | Tractor Supply Company
I'm planning to get this 15amp one to keep a charge on my batteries over the winter. It comes with a 7amp Charge controller for $129
MattStAmour
Noank, CT
Catalina 30
Hull #222
mattstamour is offline
post #4 of 21 Old 09-13-2010
mitiempo's Avatar
Matt
It is 15 watts, not 15 amps. That is barely over 1 amp at full output.
Brian
mitiempo is offline
post #5 of 21 Old 09-13-2010
thanks
I wish someone would answer Q's question. I'm gearing up for a mini cruise and there's a HF nearby.
I would also like to know if this is a good deal.
Would getting one of these go very far in making up for the draw of one of those 12 volt travel coolers I was considering?
knothead is offline
post #6 of 21 Old 09-13-2010
mitiempo's Avatar
45 watts is almost 4 amps at full output. For maybe 5 hours a day I'd guess. And 149 is a good price as far as I know.
Brian
mitiempo is offline
post #7 of 21 Old 09-13-2010
美国华人, 帆船 教授及输送
thanks
Hmmmm.....Harbor Freight usually sells very low quality stuff from China. am Not saying Chinese do not know how to make quality stuff. It is the merchant dictates the quality of the items that want to sell.
I would shy away getting it, especially for electronic stuff from HFT. YMMV
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #8 of 21 Old 09-13-2010
tommays's Avatar
In looking at the unit and looking at and looking at the Manufacturer Warranty Detail OR lack OF Warranty i would worry about the units connections and wire quality on a boat in saltwater
100% Satisfaction Guarantee! If for ANY reason you are not satisfied with this item, you may return it within 30 days for a full refund or replacement.
BUT in reading the reviews the customers seam happy and this review
Quite Curious » Boris Gets New Solar Panels
Really shows what you getting
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 21 Old 09-15-2010
Senior Mumble
jbondy's Avatar
thanks
So that would be $120? The link shows the sale price as $199.
jbondy is offline
post #10 of 21 Old 09-15-2010
4arch's Avatar
HF sends around circulars weekly (usually with Sunday coupons and it can be found online). This solar kit shows up at $149.99 almost every month. The $149.99 price does not appear to start until tomorrow, goes until 9/19 and then will be offered again 9/30 to 10/3. I'm not sure where the extra 20% off the OP mentions is coming from.
I've been tempted by this kit several times though I have yet to pull the trigger. I figure it would be a cheap way to start experimenting with solar. Just haven't figured out the best way to mount the things.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
Hunter 28 Is this a good deal? hank288 Boat Review and Purchase Forum 13 11-26-2010 08:08 AM
Good deal on a Macgregor 25? rhsanborn Boat Review and Purchase Forum 16 07-21-2010 03:24 PM
Did I get a good deal? donhaller Gear & Maintenance 7 07-17-2009 01:49 PM
Is this a good deal? ckgreenman Boat Review and Purchase Forum 5 09-06-2008 09:40 PM
Good Deal?? CherylannJohn Chartering 3 12-31-2004 09:35 PM
