09-17-2010
I have. One reason is that the stock drains were not located in positions that worked the best. The boat is a bit port heavy, as the stove, water tank, outboard engine, refrigerator and propane tank are all on the port side. It is also a bit aft heavy, due to the batteries being stowed under the cockpit. This meant that water tended to collect in the port-aft corner in the cockpit. There wasn't a drain in that corner, so I added one to get rid of the water that typically collected in that corner.
Originally Posted by legarots
Has anybody enlarged or added drains to their cockpit?
