Old 09-16-2010
LittleWingCA is on a distinguished road
Proper Float switch positioning for bilge pumps
Hi Everyone:
After washing down the sailboat this past weekend, after a great day of sailing, I noticed the bilge pump was running but no water was exiting the boat. Further inspection showed that the float switch was being activated by about 1 inch of water in the bilge, but that wasn't enough to cover the input grating of the bilge pump so the pump couldn't get rid of the water. I guess the previous owner mounted the float switch too low. Is there a recommended height above the pump that the float switch should be set up to? I guess you want to ensure the pump is immersed first, but is there any standard? Are float switches the best way to go, or are the 2 prong water sensors better?
LittleWingCA
1980 Pacific Seacraft Orion 27
Sailing Grounds: Southern California
Old 09-16-2010
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
A good question...
There isn't really any "standard" since every boat is different, but it is pretty important to follow the instructions that came with the bilkge pump and float switch. In most cases, having the switch 1" higher than the pump inlet is enough. Perhaps you can refit your switch on a block of wood to make it start later?
As to which type, I prefer the float-type because they're cheaper, more readily available and easier to replace. They also have built-in hysteresis (on and off isn't in the same place, meaning your pump isn't as likely to be stopped and started continually) which the 2-prong types don't usually have..
Hope this helps.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 09-16-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Oh for a bilge pump that can actually get to that last inch of water.....
Old 09-16-2010
Hartley18's Avatar
Termite Fodder
Oh, they do exist.. it's called a "wet vac" and you can buy one at Whitworths for less than a float switch.
Every boat should have one!!
Old 09-16-2010
I agree. I have a wetvac as well, and will use it to remove the 1" of water, but now I need to reposition the float switch as well. Question is, can you adjust the turn on and off settings to try and get most of the water out between the switch and the top of the pump opening.
LittleWingCA
Old 09-16-2010
Hartley18's Avatar
Termite Fodder
Not usually. You need to position the switch at the correct height instead.
bilge pump/float switch 3rd wire QuickMick Gear & Maintenance 3 08-27-2010 04:09 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Pump Float and Three-Way Switch Install max-on Gear & Maintenance 38 05-27-2008 03:45 PM
Float Switch addition maboyer S2 6 12-06-2007 02:28 PM
Quick question - bilge pump float switch pmoyer Gear & Maintenance 3 04-17-2007 04:43 PM
