-   -   leaking gas tanks (http://www.sailnet.com/forums/gear-maintenance/6838-leaking-gas-tanks.html)
LarryLevine 04-26-2003 08:32 PM
leaking gas tanks
I think I have overfilled my gas tank and thant is what is causing the leaking from the top of the tank. How do i know if the tank is leaking and that is not just overfill. Any suggestions on how to investigate this problem or what to do.
foxglove 04-28-2003 04:18 AM
leaking gas tanks
I''ve been there.
Is it also possible that you have a fuel line leak? If you can inspect the fuel line and assure yourself that it''s ok then the leak must be in the tank.
I would siphon the fuel down to what you think would be about half tank and observe if the leak persists. If it does, you must have a leak below the half-way mark.
If there is no leak and you add the fuel back into the tank a quart at a time and watch for leaks you might discover a leak above the half tank line. If no leaks show up, the problem must have been over fill.
Irwin32 04-28-2003 10:34 AM
leaking gas tanks
Is this a portable tank, or mounted? If it is mounted, I would guess you have a filler cap that is not vented and it should not leak under any circumstances. If mounted, check your vent hose and vent as well for leaks.
Irwin32 04-28-2003 10:37 AM
leaking gas tanks
Another thought: If you have to pump gas our of your tank be sure to use a pump designed specifically for this purpose. The wrong pump can spark from frictionl.
