Old 09-15-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
I'm looking to install a pair of these. (Ignore the price this is Australia not the US.) Anyone have any experience with Enotech panels ? They are certainly well priced compared to BP and quite frankly I'm not in the mood to buy anything from BP right now.
Solar Online Australia - Solar E 130W Solar Panel SE130P 12V Polycrystalline Solar Module
Old 09-15-2010
They don't look too bad, but they're only 55 watts each...Don't know about the brand though, as I've never heard of them until you posted. I'd look for panels from Kyocera, which are pretty highly rated...do you have room for two 3' x 22" panels on the womboat??
Old 09-18-2010
mitiempo's Avatar
Stern mount works best - no shadows. Pic from Atom site.
Brian
Old 09-19-2010
tdw's Avatar
tdw tdw is offline
SD, Apologies, I didn't see your reply to my post.
Mispelt the name btw...should be Enertech.
55w panel is 900 * 550 (36'" * 22") 5.5 sq ft
80w panel is 1200 * 550 (47" * 22") 7 sq ft
Kyocera 70 is 800 * 650 (32" * 26") 5.75 sq ft
The 1200 panel is pushing it for space but we could handle two of the E55s or two of the K70ws. In fact the K70 would fit the available space(s) better than the EN55w. Twin panels would be mounted fore/aft on either side of bimini, alternatively we could possibly go for a single K135w across the stern.
Old 09-20-2010
Fuzzy-
Go with the two K70s, rather than the single K135. First, the two panels will give you some redundancy against breakage.... Second, the two smaller panels are less likely to be shaded at the same time than the one larger panel. Shadows across a panel can drastically drop its output—so the two smaller panels may actually have an overall higher output relative to the one larger panel.
Old 09-20-2010
tdw's Avatar
tdw tdw is offline
Solar Cells for the Womboat
Moved some posts from QuickMick's Solar thread cos it was starting to look like a hijack. I originally thought the two threads were compatible but now not so.
mitiempo...if you think your post shold have stayed with the other thread, let me know and I'll move it back.
Old 09-20-2010
mitiempo's Avatar
tdw
Thanks but I think it's better here.
Brian
Old 09-20-2010
blt2ski's Avatar
Sorry Fuzzy,
Not sure the solar cells will work, lack of brain cells is just that......lack off!
Marty
She drives me boat,
I drives me dinghy!
Old 09-20-2010
tdw's Avatar
tdw tdw is offline
Originally Posted by blt2ski View Post
Sorry Fuzzy,
Marty
Here's me thinking that with my thinning pelt a solar array could put some heat back into my system.....
Old 09-20-2010
Hey, no picking on Fuzzy...he's only got the two brain cells, and they're working as hard as they can....
Womboat Hatch ID.....Help !! tdw Gear & Maintenance 6 03-02-2009 07:00 AM
womboat Cruise 09 tdw Cruising & Liveaboard Forum 29 01-30-2009 06:32 PM
Wombat seeks your opinion on a possible new Womboat. tdw Boat Review and Purchase Forum 139 07-28-2008 03:14 AM
think they use solar ? sailusvi General Discussion (sailing related) 0 10-08-2007 08:12 PM
GPS and Solar Flares NewsReader Mass Bay Sailors 0 04-05-2007 06:15 PM
