Old 04-28-2003
gwp gwp is offline
gwp is on a distinguished road
Depth finder question??
Have an older model depth finder which has a dial type face with a "spinner" which produces a red dot to indicate depth on the dial. When on, the spinner works but reads 0-3 feet regardless of the actual depth. A wire runs from the unit to the transducer which is mounted beneath the V berth. I guess it''s the transducer.....it looks like a ~1" pvc pipe about 6" long sealed to the hull, with the wire going down thru the top. Question....Does the transducer ping thru the hull? Because there is no thru hull type fitting on the outside of the hull. Just trying to make this thing work. If anybody has any ideas, I''d be grateful.....Gary
Old 04-28-2003
GordMay is on a distinguished road
Sounds like a, shoot thru'' the hull, Transducer. Transducers have a finite life. Likely, yours is dead and could be buried.
These type of Sounders (Flasher) can be had for < $100, so not much point in seeking a $150 replacement ''ducer.
Sorry,
Gord
Old 04-28-2003
Irwin32 is on a distinguished road
I found that VC17 bottom paint seemed to stop my transducer from working inside the hull. As long as the present transducer is mounted inside, remove it, submerge it over the side and test it that way.
Old 04-28-2003
fourknots is on a distinguished road
Is this new to you or was it working before? My "spinner" had a the light width indicating battery voltage (pretty clever) when it was turned on and before it was adjusted. After adjusting the gain (I think) it would read fine.
Maybe there is a limited tranducer life, but mine was 31 years old and worked fine.
Old 04-28-2003
gwp gwp is offline
Yea, I wouldn''t consider an expensive fix on this old girl. However, there might be an easy fix. I just don''t know anything about them. I have checked very good and am sure there is nothing on the outside of the hull opposite the transducer. The piece of pipe has much blue silicone looking stuff globbed all over it''s base (very messy job) as if it was to stop a leak? Or maybe to "glue" it in place? I have a horror of manhandling it to get it off to check it out thereby sinking my boat. It''s something about working below the waterline that makes me nervous. Thanks....Gary
Old 03-01-2006
popsla is on a distinguished road
It sounds like a oil box for the tranducer to sit in to shoot throught the hull. It should be filled with oil so that the tranducer can shoot throught the oil and the hull, the transducer won't work through air. It could have leaked out, it won't work with the oil gone. If you can get the top off to get the tranducer out, you can check the transducer by putting in in a baggie of water and putting that against the hull.
Old 03-01-2006
yachtvalhalla's Avatar
Cruise-aholic
yachtvalhalla is on a distinguished road
For what it's worth you may want to look at my article at:
http://yachtvalhalla.net/articles/tr...ransducer.html
I gave up on the oil bath technique and epoxied the transducer directly to the hull, as described in this article.
Terry
Old 01-03-2009
whatoo's Avatar
whatoo
whatoo is on a distinguished road
Send a message via Yahoo to whatoo
My depth sounder is a Uniden and the transducer is of another brand. What do I do to merry the wiring together? transducer to depth sounder?
Thank you, Whatoo
[/SIGPIC]
Old 01-06-2009
whatoo's Avatar
whatoo
I want to use a Uniden depth sounder. The transducer that is a thru-hull, is of another brand. I would like to leave the transducer in place and splice my depth sounder to the existing transducer. The transducer is a simple transmit/receive type, without a paddle. Can this be done?
[/SIGPIC]
Old 01-12-2009
Whatoo—
You really shouldn't be reviving a dead thread that was over seven years old to being with.
As for wiring a Uniden depth sounder to a different transducer, it depends on who made the transducer and what signal input/output it requires. Many transducers are made by Airmar, and in many cases, they can be used on different display heads without an issue.
If the wiring is the same number of wires and colors, there's a very good chance that the transducer will work on the Uniden, even if the transducer did not come with it.
BTW, you might be a bit confused, as I've never seen a depth transducer with a paddle. The paddle is for a knotmeter, and might be found on a triducer—that does speed, depth and temp... but never on a depth transducer.
I'd highly recommend you read the POST in my signature to help you get the most out of your time here. It has tips on searching sailnet, writing a good post, etc..
Depth Transducer Question gwp Gear & Maintenance 0 07-13-2003 05:38 AM
Depth Gauge vs. Fishfinder larsfis Gear & Maintenance 2 02-16-2003 06:27 PM
Hints on Depth Finder RookieHunter Gear & Maintenance 1 01-07-2003 09:16 AM
Cost of depth sounders vs fishfinders waltzingmatilda Gear & Maintenance 7 01-30-2002 09:48 AM
depth sounder dillemna chuckg Gear & Maintenance 6 11-12-2001 07:53 AM
