09-22-2010
6"x 6" is pretty small. Chances are the area of wet/rotten core is larger. My question is, have you drilled out a core sample so you know what you're really dealing with? Sounds like it's around a bow cleat or the like that wasn't bedded properly. You can go at it from the bottom if you're under d=12" circle. Any larger and it can get a little difficult and much depends on the thickness of the interior gelcoat... no easy answer... If the core is only damp and there's no rotten or really wet core or spread, you can vent the area from the bottom (use a 2-3" hole drilling bit and remove just that circle of gelcoat/glass to expose the balsa. Sea Dog makes $8 plastic vent covers that will neaten things up, then just religiously run your dehumidifier to dry things out. After it's dried out, you can leave it as is, or go ahead and reglass/gelcoat, and paint to match. As far as going through the top, if you have some good paint/texture matching skills, it's a very small area and should be pretty easy to do. In the worst case, you might repaint and re-texture to the extents of that particular area... Not many boats have the entire deck textured without breaks. Another thought is do the repair from the top, re-core, prep for paint, then farm it out. By that point, you're probably looking at 2-3 hours of labor at the max to finish up, and it will look much better if your own skills aren't quite there. In the end, it's the prep that really takes time. If you can do that, you'll save a bundle.
