Old 09-22-2010
rmeador is on a distinguished road
LP gas warning label
On my boat, there's a warning label on the bottom of the lid of the LP gas locker. This label has just about completely worn off. My insurance company wants me to replace it, but I can't find such an item on Defender or West Marine. Do any of you know of a source? The insurance company says it should say (and it's unclear if this is an example or exactly required):
WARNING
Liquefied propane gas (LPG) is flammable and
explosive. Follow these instructions to avoid
injury or death from fire or explosion.
• This system is designed for use with
liquefied petroleum gas
(LPG/propane/butane) only. Do not
connect compressed natural gas (CNG) to
this system.
• Keep LPG cylinder and/or solenoid valve(s)
closed when the boat is unattended, and
when appliances are not in use.
• Close cylinder valves immediately in any
emergency.
• Keep empty cylinders tightly closed.
• Close all appliance valves before opening
cylinder valve.
• Apply ignition source to burner before
opening appliance valve.
• Test the system for leakage in accordance
with the instructions required to be posted in
the vicinity of the cylinder each time the
supply valve is opened for appliance use.
Never use flame to check for leaks!
1979 Gulfstar 37 Laissez Faire
Old 09-23-2010
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
Try a "propane locker" manufacture website.
A welding gas supply would also have a generic label that might work.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 09-23-2010
whroeder's Avatar
whroeder is on a distinguished road
Originally Posted by rmeador View Post
WARNING
Print the copy from http://www.acemarineinsurance.com/ac...tedLanguage=en
And attach it to a laminating sheet (JM#43192)
WARNING -- Scam pegasus1457 General Discussion (sailing related) 18 12-16-2007 11:29 AM
UK. Repeat warning: Check your White Collision Warning Flares now, don’t risk serious injury @ BYM Sailing News NewsReader News Feeds 0 04-13-2006 08:15 AM
WARNING!!!!! Speedy92152 Cruising & Liveaboard Forum 10 11-25-2001 06:02 AM
Hurricane Warning Ralph Doolin Seamanship Articles 0 08-03-2000 08:00 PM
Hurricane Warning Ralph Doolin Cruising Articles 0 08-03-2000 08:00 PM
