Old 09-23-2010
rmeador is on a distinguished road
lubricating traveler and genoa cars
What is the right lubricant to use on my traveler? WD-40? Can the same lube be used on the genoa car track? My traveler is so sticky it won't move without being pushed hard with my foot (not kicked). The genoa cars move well enough, but it seems to me they could move more easily. Also, while I'm on the subject, the dorade vents don't turn very well, what would be a good lube for that?
1979 Gulfstar 37 Laissez Faire
Old 09-23-2010
DropTop's Avatar
DropTop is on a distinguished road
I use sailkote for the cars and track. mine will slide like they are on ice if the pins are locked out.
Harken says to use it on anything that moves... not sure about clear hatch covers though.
Four Points - 1990 Hunter 27'
Old 09-23-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Lanocote is good.......I'd not use WD40 as a lubricant....
Old 09-23-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Wrongo old son. It attracts and retains grime as does WD40 and any oil based lube.
For these parts one wants/needs a dry lubricant. Drop Top had it right--SailKote. For further/added references see Harken and/or Lewmar's maintenance pages.
Old 09-23-2010
tdw's Avatar
tdw tdw is offline
bugger....
I hadn't thought to use SailKote genoa tracks etc.....to be honest I have used Lanocote and while yes it does cleaning off from time to time its nowhere near as bad as WD40.....
Old 09-24-2010
Ok, I guess I'll have to pick up some SailKote. Thanks!
Old 09-24-2010
christyleigh's Avatar
christyleigh is on a distinguished road
...... And also McLube Sailkote for your sail tracks, boltropes, and slugs - raise without winching and drop like a stone
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 09-24-2010
puddinlegs is on a distinguished road
McLube One Drop for both... if you're already to the point of kicking your traveller down, you're probably in the realm of very worn bearings. Time to replace them is my guess.
Replacing Genoa Track Cars. tager Gear & Maintenance 6 01-25-2009 08:50 AM
Low profile genoa lead cars. zz4gta Gear & Maintenance 5 06-16-2008 06:19 PM
Lubricating heads? Joesaila Gear & Maintenance 11 08-26-2007 10:16 AM
Looking for advice on Genoa Tracks & Cars sjacovino Gear & Maintenance 8 12-09-2006 03:13 PM
Lubricating mast track BrianConley Gear & Maintenance 7 06-09-2001 07:52 AM
