I purchased a boat last fall and am in the process of refinishing it. The prior owner mentioned that they touched bottom at some point and that the only damage they noticed was a crack in the cabin floor fiberglass.
I check the hull and it is intact.
I started cleaning up the broken fiberglass and wet plywood and realized that the crack was deeper and going through what I think is
epoxy (that layer of
epoxy levels the floor and sits in the hull). That crack creates a leak in the bilge and now, any water runs through the cabin (under the floor) instead of collecting in the bilge.
Any idea, recommendations... on how to go about fixing this situation.
Thanks a lot.
