09-23-2010
insulation for winter liveaboard
As I begin moving my stuff aboard my boat, it occurred to me that if I'm going to insulate, I should probably do it before I fill every space with my stuff
I'm thinking I'm going to only insulate the lockers/storage areas, basically everything that is closed off and out of sight. I have no intention of insulating the overhead or the outer walls that are exposed to the main living space. I'd like to make a permanent installation, not something I take out in the spring. Obviously the insulation needs to be flexible so it can conform to the shape of the hull.
What kind of insulation would you suggest? What kind of adhesive would you use to attach it? Do you think I should wait to install insulation until after I've had my espar system installed (avoids possibility of it being damaged during the espar installation), or should I do it before hand (easier access to tight spaces)? Thanks!
1979 Gulfstar 37 Laissez Faire
