Old 09-25-2010
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Keel cooled refrigeration
How do these refrigeration systems work? Advantages?
Old 09-25-2010
deniseO30's Avatar
Lies about her age
the compressor pumps the hot gas into a plate that has tubes in it. The plate in on the bottom of the boat the water takes the heat away and allows the hot gas to condense. You would not need a water pump or tube type heat exchanger for this set up-- should be pretty efficient. negative would more holes in the bottom of your boat.
Old 09-25-2010
Omatako's Avatar
Omatako will become famous soon enough
There is a company that makes water-cooled condensors that fit into the drains of your galley sink and use the water washing in and out of the drain to cool the condensor. They are reported to be super-efficient and absolutely trouble free.
Check it out here: 2051 SP The little gold-colored fitting shown in the picture is the condenser that is basically a skin fitting to which the galley sink drain attaches.
The average power consumption is reported to be just 0.6amps! I have seen them running on local boat shows and they are brilliant.
I have no connection to this product other than I intend fitting a fridge and freezer unit to my own boat.
Arthur C. Clarke
Old 09-25-2010
deniseO30's Avatar
Lies about her age
thats pretty slick! I think it works because it would be below the water line. Otherwise one would have to drain allot of water!
water cooled in any kind of hvac has always been more efficient.
Old 09-26-2010
Omatako's Avatar
Denise, being a skin fitting for the sink drain it is well below the water line and the condenser comprises a small coil that is essentially wrapped around the drain pipe. The seawater sluices continuously around the coil and cools the gas before it returns to the compressor.
Arthur C. Clarke
Old 09-26-2010
SV Skalliwag #141
Thanks for the info. I knew of geothermal heat pumps, never thought the same technology would be applied on boats for refrigeration.
Old 10-15-2011
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Omatako, have you installed this yet? How do you like it, what was the cost?
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 10-15-2011
svjobeth's Avatar
svjobeth is on a distinguished road
We've been looking at a keel-cooled system as well. We've not seen the sink-drained condensers before; sounds interesting.
Bill & Lisa Ballard
S/V Jo Beth
1984 PSC Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
Old 10-15-2011
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Shawn - I may have noted in the other refrigeration thread. I have two Isotherm SP units on Auspicious. After 5 years I continue to be very happy with them.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 10-15-2011
mitiempo's Avatar
Frigoboat Frigoboat Home Page is a very highly rated system that has a keel cooler that uses no power at all. A neighbor installed one and loves it - very efficient.
Brian
Raw water cooled issues? davidpm Diesel Engine Forum 5 11-10-2009 09:15 PM
Adler Barbour Water Cooled Refrigeration bobbosax Gear & Maintenance 1 12-26-2008 10:27 AM
Raw water cooled engines Neicy Gear & Maintenance 10 05-16-2005 12:14 AM
volvo md2b raw water cooled fsmith Gear & Maintenance 6 04-28-2003 10:48 AM
Raw-Water-Cooled Engine Mark Matthews Gear and Maintenance Articles 0 12-26-2001 07:00 PM
