Old 09-25-2010
heidiho1964 is on a distinguished road
Mounting solar panels on stanchion
We have two 135W solar panels and are looking at our options for mounting them. The least expensive would be to mount them on the aft rails. However, it was brought to our attention that this can cause strain on the stanchions if they are not supported and ultimately lead to leaks. Supporting the stanchions is not an option as it will cause a hazard (tripping over support). Has anyone had, or heard of, this problem with the stanchions?
Thank you
Heidi
SV Gypsy Wind
Old 09-25-2010
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
We have two panels (125w and 85w) attached to our lifelines forward of the stern pulpit. To do this we replace the wire with 1" stainless tubing that we had welded together in Carriacou last winter since there was too much movement when everything was just bolted together. I imagine that your stern rails are already U-shaped so there would be support already. Our panels are mounted using rail clamps (2 for each panel) and then swung out to horizontal when we want to use them (pretty much all the time except when docking on that side). The outer edge of the panels is supported by a cedar 1 x 4" that is rounded at one end to fit on the lower lifeline rail and notched to fit the panel. Works great.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 09-25-2010
gershel is on a distinguished road
That sounds really interesting. Any pictures?
Thanks, Marc
Stanchion base mounting blocks 4arch Gear & Maintenance 3 07-30-2010 01:42 PM
solar panels johnnyboats Gear & Maintenance 25 11-14-2008 09:24 PM
Solar Panels bottleinamessage Jeanneau 0 08-16-2007 07:10 AM
Solar Panels BlueWaterWannaBe Living Aboard 7 02-26-2007 05:08 PM
ideas for mounting solar panels on a 32 ft. sloop kmeeks Gear & Maintenance 3 12-14-2003 10:15 AM
