09-26-2010
Originally Posted by tdw
Why isn't a pole ever used on an assy ? I've never used one ddw but kind of figured that a pole would helpful under that circumstance in much the same way as a poled out genoa.
Nowadays A sails are flown from sprits of various lengths, as I'm sure you're aware.. I think the issue with Spinn poles is that for the right luff length they need to be low on the deck, and the rigging isn't really set up for that. Further, the sprits extend quite a bit further than the normal SPL, so trying to convert a pole to an effective sprit is going to take extra gear and some kind of bobstay setup to keep it all together.
However, the idea of using the pole to get the tack out to windward on a deep reach/run makes some sense... I've recently acquired a used A sail so may try it in the future.
1984 Fast/Nicholson 345
