09-27-2010
1974 Catalina 22
Originally Posted by brak
What other small outboards (about 6hp) should I consider?
I like the old Evinrude/Johnson six horsepower two stroke twins. They're much smoother and simpler than newer 4 stroke 1 cylinder motors, and still pretty quiet and light weight. Mine is a 1967 and still runs like new after a tune-up, although the newer models with electric ignition are nice because you don't have to replace/adjust points.
I paid $200 for it, and another $100 or so for new points, fuel pump, carb rebuild kit, water pump, spark plugs, lower unit oil, and pull rope.
It weighs 50lbs which is about the same as the new single cylinder 4 strokes, and much less than the two cylinder 4 strokes.
