Old 09-28-2010
bandit1 is on a distinguished road
Standing rigging change-DIY or professional?
I bought my Ericson 38-200 a year ago. Its a Great Lakes boat but my intention is to head down the east coast and the Caribbean (saltwater area's) next fall. The boat is 20 years old and to the best of my knowledge the standing rigging has never been changed. Now I am not loaded but like anyone if I can save some money I will. My mast is down now so this would be the time to do it. However is ths something I should leave to the professionals? Should I just get rid of all those wires and put rope? Does anyone have rope shrouds and what do you think?
Old 09-28-2010
QuickMick's Avatar
QuickMick is on a distinguished road
http://www.sailnet.com/forums/gear-m...eplacment.html
knothead will hook you up
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 09-28-2010
cruisingdream is on a distinguished road
standing rigging last 30+ years in the great lakes so your standing rigging may have several years of saltwater work left in her
have a good rigger inspect it , it may save you a few$$$
Old 09-28-2010
Thanks QucikMick, ya I just read that link some good stuff in there however that thread turned into a debate about furling or hank sails and rod rigging.
Old 09-28-2010
mitiempo's Avatar
Here's a good link to synthetic rigging if you want to explore that route.
Home
To replace in stainless take your current rigging to a rigger and get them to swage the top ends of the new wire and use Hayn HiMods for the lower ends.
Brian
Old 09-28-2010
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
My personal opinion...
Synthetic rigging is a neat idea, but still in the early stages. We know wire rigging lasts a long time because it has been around a long time. synthetic rigging might last a long time, but that has yet to be proven.
For racers looking for a performance gain, people who like to experiment and be on the leading edge, even if they fall off a time or two, people who can afford the risks of experimenting I think synthetic rigging is a good and interesting option.
For me personally, it is still a bit too new, and I would not want to be sailing off shore or in remote areas with it, nor take the chance of things going wrong. I am just not at a place where the risks of trying it are worth the benefits. Others are and good for them, that's the only way it will get tested for the long term. Which camp are you in? Only you can decide, but from your post, I would advice to stay away from synthetics for the reasons listed above, but that's just advice.
As for changing the rigging yourself, if you have the mind and the time, I say go for it, but if you can find a professional rigger to get the materials from and perhaps some advice and a little help if needed, that might be a good idea.
I wanted to do a lot of the rigging on our boat to save money but more to know the rigging well, but due to time and the distance form the boat I was not able to do much. I worked with Port Townsend Rigging (In Washington State) and really enjoyed working with them. They let me do a bit of the work, as long as the mast did not take up room in there yard too long, and billed by the hour for their work. So basically, if I could cut down their work, I saved money, if I needed a lot of help and got in the way and made their portion take longer, it cost me more.
I was there when the mast came down and helped, and then stripped all the old rigging off, labeled it and rolled it up so the riggers could use it for reference. I rewired the mast (electrical) and after the new rigging was ready to attach, I worked with one of the guys to get it all attached to the mast and then was there and helped a bit getting the mast back up and installed.
I feel this worked well for me in my situation. I feel I was treated very fairly by the riggers, was able to save a little money doing a few things, was able to learn a lot through the process and was able to rely on the riggers knowledge when odd things came up (which many did).
For instance, I wanted to move from rope/wire halyards to all rope, but the sheaves where for wire only as the rope never reached them. To compound the issue, the mast head slots where not wide enough to take standard sheaves. The riggers saw the problem, called a local machine shop they work with regularly and had custom sheaves made at a very reasonable price, and suggested the correct line we would need for the halyards as they would need to be a bit undersized to fit through the mast head.
Figuring out all of this would have taken me a very long time, and likely would have cost me a lot more to have the sheaves made, after I bought the ones that would not fit, etc. Of course working with a different company I may have ended up getting taken to the cleaners with all of this, but again, I feel they handled it well and treated me very fairly, I would recommend them to anyone in the area.
Swagged vrs. mechanical fittings is another big debate. I originally wanted to go with all mechanical fittings as I could do them myself and work on them myself should I need to replace a stay at some point. Port Townsend Rigging could have actually made more money selling me mechanical fittings, but instead talked with me for quite a while about the different technologies, and I finally decided to go with swedged fittings and get a couple of mechanical fittings for replacing wires at sea if needed. In the end, it was cheaper to go this route then to get all mechanical fittings and assemble them myself, and I am very confident in the quality of the swedged fittings.
As an avid do-it-myself-er, it was a little odd to hire the riggers rather then doing it myself, but in the end I am very happy I did. Standing rigging is a very crucial part of the boat and a major safety concern. I feel I got a rig I can trust, and learned enough to be able to work on it myself in the future in a pinch, and all for a reasonable price.
But if you have the time and desire, doing it all yourself could be a fulfilling way to go to.
S/V Lilo
1964 Islander 32
Saint Helens, OR
Old 09-28-2010
Da Most Educated Red Neck
rockDAWG is on a distinguished road
Synthetic rigging makes no sense to me for boat. It may be easier to use and light wt, but too many disadvantage for sailboat use. The 10 year old synthetic rope will look very beat when compared to SS riggings.
Starting 2012 sailing season: Done with the timeshare boat.
Old 09-28-2010
olson34 is on a distinguished road
Lightbulb One place to look...
Replace Standing Rig -- Costs/Options? - EY.o Information Exchange
Pretty Good thread, with several links to other rigging threads.
I hope you are active on the Ericson owners' site.
Lots of info there.
Old 09-28-2010
ccriders is on a distinguished road
Before you do anything call Rigging Only at 508 992-0434 and get a quote. You can ship them your old stuff, they duplicate it and ship it all back to you. So easy when the mast is down. Then you have all new rigging and back up in the form of your old stuff. Their prices are very competitive.
John
Old 09-28-2010
I would second Rigging Only.
I'd also point out that a vandal with a knife can do a lot of damage to a boat with synthetic rigging and far less to one with stainless steel wire rigging.
IslanderGuy's suggestion of replacing the wiring is also a good one. Doing it now, while you've got the mast down, is a really good idea.
Standing Rigging, DIY or pay a Professional? LandLocked66c Gear & Maintenance 14 07-20-2010 07:14 PM
Standing Rigging Re-do dmkey C22 6 05-23-2010 10:20 AM
Standing rigging katocomb Gear & Maintenance 13 05-21-2007 03:52 PM
Standing Rigging Sailormon6 Gear & Maintenance 3 05-05-2004 05:30 AM
Standing Rigging docsabre Gear & Maintenance 2 05-18-2002 04:48 AM
