Old 09-29-2010
Garry0wen is on a distinguished road
So I got my first boat... HELP!
It don't have a rudder and from what I've read I'm gonna need one
this is the boat, it's 21' long and has a retractable keel (there is a winch in the cabin that raises/lowers it)
This is where I imagine the rudder should be
from looking at pictures online, I figured I would need these bits to attache/use the rudder with
The next thing I need is the rudder itself. I couldn't find any mention of the boat I have anywhere online. It's listed on the registration as a "Classic Marine" boat, but there is no data plate or other name anywhere on the boat with the exception of the numbers stamped onto a strip of metal that is molded into the back of the hull. So How much rudder do I need above the transom and how much do I need protruding below the bottom of the boat? And how wide does it have to be? I know the thickness from the mounting brackets I have, but how much tapper is there from front to back?
Old 09-29-2010
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
The numbers stamped into the transom plate will include a code for the builder and model and the date when the hull was built along with the hull number. If you could find out the model you might be able to find a similar boat and get the rudder dimensions.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 09-29-2010
gedaggett is on a distinguished road
Model year and make will be needed for sure.
I would rather admit I'm a fool with the posibility of finding I am not, than to deny it showing all the I truly am.
Old 09-29-2010
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
Go to the rear of the boat, to starboard side. Read that number on the top of the transom and post the first few letters if you're not comfortable posting the whole thing. The letters at the beginning of your HULL NUMBER will identify the manufacturer of the boat.
If there's a shore power plug in the cockpit, there's most likely a plate next to it, which will ID the manufacturer.
How tall is the mast, and how long is the boat, as well as how wide?
Water is Life
Old 09-29-2010
RJesser is on a distinguished road
Cal?
If you have not yet found the model number yet. It looks like a Cal 21 to me. More pictures may help.
Old 09-29-2010
glassdad is on a distinguished road
It is a Clipper Marine 21. I don't know the year.
Old 09-29-2010
casioqv's Avatar
1974 Catalina 22
casioqv is on a distinguished road
Take my advice with a grain of salt, because I'm not a marine engineer, but I suspect a used rudder from any boat of roughly the same displacement and length will work- Catalina 22, Venture 21, San Juan 21, etc. but you might need a matching set gudgeons to mount it. If you have a huge budget and want a really awesome rudder, IdaSailor can make you a brand new one (idasailor.com).
Old 09-29-2010
Go here for data on the boat including a line drawing.
CLIPPER MARINE 21 Sailboat details on sailboatdata.com
Clipper Marine boats are lightweight boats and are fun to sail.
Enjoy!
Old 09-29-2010
casioqv's Avatar
1974 Catalina 22
Enjoy!
Wow, only 1650lbs! That thing must do really well in light winds. Maybe a rudder from an 18 foot boat would be more appropriate than from other 21/22s?
Old 09-29-2010
more pics...
It didn't have a hatch cover so I made one. I also sanded and stained the rest of the wood handles and such (thick coat of urethane afterward)
it would in fact appear to be a Clipper Marine 21...
WANTED: BASIC BOAT BBQ. CHARCOAL IS OKAY, BEATUP IS OKAY, ANY BOAT BBQ - $25 seattle stephenronning Gear & Maintenance 2 03-30-2009 09:21 AM
Coast Guard finds missing boat, still searching for other boat - FayObserver.com NewsReader News Feeds 0 05-11-2007 11:15 PM
Coast Guard finds missing boat, still searching for other boat - Access North Georgia NewsReader News Feeds 0 05-11-2007 10:15 PM
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 04:15 PM
Coast Guard finds missing boat, still searching for other boat - Myrtle Beach Sun News NewsReader News Feeds 0 05-11-2007 08:15 AM
