To Spartite or not to Spartite - that is the question? - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 10-03-2010
Tartan 37C
T37SOLARE's Avatar
One of the very first projects we did was to Spartight the mast partner, and I'm still very pleased with the results. We installed it to another boat I help maintain, and the stick has been in and out 4 times in the last 6 years it's still as good as new.
You'll still need a mast boot, and you'll still get water in through the mast sheaves, but you can kiss the mast wedges goodbye forever!
Highly recommended it.
SOLARE
T-37 #442
T37SOLARE is offline
post #12 of 16 Old 11-25-2013
L124C's Avatar
Rust stains?
Though some here say Spartite is not a seal, I sealed the perimeter (where the Spartite contacts the partners on the top edge.) with silicon as instructed, and it has remained bone dry below for years. However, the silicon seal has now split and I'm getting some water below at the partners. I can re-seal it of course, but what concerns me is the rust colored stains the water has brought with it. The mast is aluminum, and most of the water would be fresh. Tried to post a picture, but can't for some reason. What could be making the stains?
BTW, I use a canvas boot to protect the Spartite from UV.
Having rigged and tuned my boat several times, I disagree with post #4. Setting the wedges (or Spartite which replaces wedges) is the first thing I do. They should remain in place as they perform a function the other rigging components cannot.
L124C is offline
post #13 of 16 Old 11-26-2013
ebs001's Avatar
Re: To Spartite or not to Spartite - that is the question?
I just painted the Spartite as per some instruction I got on line.this was done to give it UV protection.
My mast is out right now because I'm having new standing riging installed and the Spartite collar came out nicely when they removed the mast.
Been real happy with the installation especially the no creaking.
ebs001 is offline
post #14 of 16 Old 11-26-2013
We've had it last 2 boats. Please be advised that the only capes we ever round are labeled Cod, Ann, and Elizabeth.
It seems to work fine to center the mast in the partners. It doesn't fall out in a seaway, as wedges sometimes do. We agree with other posters, it helps but doesn't solve the water tight issue without help. We believe it distributes the load on partners better than wedges, but can offer no proof of this but seems to pass the common sense test.
The 52 we owned previously had heavy hood furl mast. On that one, we had trouble occasionally in the stepping process, where the donut material would slip downwards on the mast on removal before breaking free of the partners. It would with some effort go back into place when we put the mast back.
I'm not having the problem with the much easier to step mast (lighter) on our smaller current boat.
capecodda is offline
post #15 of 16 Old 11-26-2013
The first thing I do on every keel stepped boat is get the mast in the right place, then spartite it. Wedges do not give the same level of security for placement as it does, and having them pop free while out sailing is a miserable experience.
I wouldn't consider it a cure for water intrusion by itself, but it goes a long way towards solving the problem. I typically add a mast boot on top of it, or flashing tape depending on the boat. On the race boats we just leave it exposed and figure a little water is worth the access.
Greg
Stumble is offline
post #16 of 16 Old 11-26-2013
GreatKetch33
Deric's Avatar
I have Spartite on both masts of my cat ketch. It works great. Every year I unstep the masts for winter storage and then step them both in the spring. After four years, the Spartite sets the mast perfectly -this is critical because these carbon fiber masts are secured with stainless steel rods at the keel column and the alignment is important.
A rubber seal made from tire tube and a sunbrella boot protect the wedge from UV while keeping the boat dry below.
Very happy with the product.
Happy sailing,
Great Ketch
Deric is offline
How NOT to install Spartite! L124C Gear & Maintenance 10 01-14-2012 02:28 PM
Spartite reignmaker Gear & Maintenance 16 06-16-2010 05:52 PM
Hi...I'm new and have a question... KeltiC Introduce Yourself 6 10-20-2009 11:50 PM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 08:25 AM
Spartite 2000 mast wedge replacement system - need info Capt.CarroleWard Gear & Maintenance 2 05-30-2001 07:01 PM
