Old 09-30-2010
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
changing from 4 stroke to 2 stroke
i currently have a 1997 v8 horse honda 4 stroke engine on my ib 24 looking to change to 2 stroke (easier to work on) what size 2 stroke should i use
also the honda wont fit in the well on the boat i am looking to get rid of the o/b bracket
Illegitimus Non Tatum Carborundum.
Old 09-30-2010
You have a 8 HP four-stroke, why not get a 8-9.9 HP two-stroke to replace it. That would be lighter than the four-stroke and give you about the same HP or a bit more. You'll want a High Thrust prop for the outboard though. Most 8-9.9 HP two-strokes will fit in the outboard well, since the well was probably designed for a two-stroke outboard originally.
Old 09-30-2010
newhaul's Avatar
islander bahama 24
thats what i was thinking the vessel was made in 1966 however as with most islanders from that age i cant find any info on what engine was recommended by factory spec. as far as weight my friend has an 18 hp evinrude and it weighs less than my Honda. I'm looking to get plenty of power but get rid of as much of the weight as i can. thanks for the prompt reply.
Old 09-30-2010
dabnis is on a distinguished road
Newhall,
I had a 15HP 2 stroke Evinrude, same size and weight as the
9.9HP, on a Coronado 25. Worked great, the 9.9 may have been
enough? Don't know what your well configuration is but if you
do some measuring beforehand you should have an estimate as
to whether it would fit. Suggest you get a long shaft version.
The high thrust props were not available then so we went down
an inch or so from the stock prop and had all the thrust we could use.
We used the motor hard for 10 years with no problems.
On my present 2 stroke motor I switched to synthetic 2 stroke
oil, same 50:1 ratio, and the smoke was noticeably reduced.
Dabnis
Old 09-30-2010
tommays's Avatar
Well
If you live in the US the 2 stroke thing is only gonna happen used
If outside the US you may be in and area were there still legal to buy new
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-30-2010
mitiempo's Avatar
It's not illegal but Evinrude does not make a small engine anymore.
Brian
Old 09-30-2010
Newhall,
I didn't see your last post before my last reply. Your local Craigslist
may be a good source for a used motor.
Dabnis
Old 09-30-2010
Cruisingdad's Avatar
Best Looking Moderator
I bought my 15hp 2 stroke yamaha around April of this year. Yamaha discontinued production on them the summer before, but many dealers are still sitting on them. Shop around and see if you can get one from them. The new 2 strokes are super engines.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 09-30-2010
It is a 24' boat... it really doesn't need more than 9.9 HP to move it.
Old 10-02-2010
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
i agree with sailingdog. A 9 hp is all that is needed to move the boat. I had a Catalina 22 with a 9 hp 2 stroke ob motor which pushed her just fine!
Tod
Problem changing gear lube on Mercury 3.3hp 2-stroke bacoms Gear & Maintenance 16 06-16-2009 12:20 PM
With the stroke of a pen RickQuann Off Topic 4 08-01-2008 10:08 AM
Yamaha 9.9hp 4-stroke WagTheDog Gear & Maintenance 7 04-23-2008 10:32 AM
2 stroke vrs 4 stroke outboards dsbentley Gear & Maintenance 11 07-10-2006 11:27 PM
Tohatsu 6hp 4-stroke? safarisurf Gear & Maintenance 3 07-06-2006 11:43 AM
