Sealant for Lexan/fiberglas/teak - Page 3 - SailNet Community
post #21 of 26 Old 10-02-2010
jd-
Boedeker Plastics : How to Identify Plastic Materials Using The Burn Test
You can identify plastics with a simple burn test (scrape a bit off the edge) or with solvent tests. If you get some scrap from a local plastics house, you'll have something to compare yours to, and that will make it easier to identify.
hellosailor is offline
post #22 of 26 Old 10-02-2010 Thread Starter
Courtney the Dancer
jrd22's Avatar
Good idea, thanks HS.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #23 of 26 Old 10-04-2010
WE use Silpruf...as it retains the most flexibility. Its adhesion to teak...should be fine...but check.
Annapolisboater is offline
post #24 of 26 Old 10-04-2010
blt2ski's Avatar
Looked at my boat today, it appears as tho the caulking for lack of better term that is on the top of the lexon is worn out or equal, and letting water in at the top. Did this 5 yrs ago, so will have to do it again I guess. Then again, along with this bead redoing, may pull the thru screws an re caulk too. This takes to people vs one.
Will check out Atlas supply to, Hopefully they have a clear for the bolts, and black for the upper and around the window part.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #25 of 26 Old 10-14-2010
silpruf, silpruf, silpruf.
post #26 of 26 Old 10-14-2010
Thumbs up
We rebedded four lexan (c) large fixed-port lenses in '95 with LifeSeal. Still never a leak.
It just works.
Note though... that are some simple tricks of the trade to get a permanent seal with the more-thermally-active Lexan.
L
olson34 is offline
Fiberglas hull TLC jetdrvr393 Gear & Maintenance 4 09-29-2009 12:38 AM
Sealant for bedding steel hardware on teak rail? josrulz Gear & Maintenance 3 06-05-2009 04:06 PM
plexiglass or lexan prussell Gear & Maintenance 1 04-23-2004 01:17 AM
plexiglass or lexan prussell Gear & Maintenance 2 04-22-2004 07:59 PM
lexan maestro Gear & Maintenance 4 02-19-2004 08:45 PM
