Old 10-01-2010
QuickMick's Avatar
QuickMick is on a distinguished road
new handrails
the old handrails were shot. removed/holes filled. now i need to replace 'em. it seems that the choices are stainless or teak, and i probably wont go the stainless route. two questions: are there any other materials that can be used? secondly, im thinking of using two seperate rails per side instead of one long one, but am concerned about snagging issues?
here is what the mounts looks like (is there a standard size they all meet?) :
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-01-2010
BigZ is on a distinguished road
Starboard?
There are a few threads on this. Looks like your application, with those pads part of the deck, might call for a fairly slender piece of starboard. Not sure if I'd feel good about that. Teak or SS sounds better.
Also, with those pads built in to the deck I'd lean towards a single piece, simply from an ascetic point, but that's a personal choice. I don't think snagging would be an issue.
Old 10-01-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
If it was my boat I'd probably go for Teak. SS will get hot in the sun where you are in TX.
I hope you saved the old hand rails for basic measurements unless they were too far gone.
Some outfits sell off the shelf pre-made handrails that are more or less standard with many boats (sailnut, defender etc.). If you have the time and inclination it isn't that difficult to make your own.
Rebedding handrails that are not through-bolted josrulz Gear & Maintenance 35 07-11-2010 04:25 PM
where2buy non-standard teak handrails dreuge Gear & Maintenance 13 02-10-2010 04:06 PM
teak handrails bsiege Gear & Maintenance 6 04-01-2009 04:10 PM
capping bolts in handrails marcusn Gear & Maintenance 2 05-18-2008 10:32 AM
Installing Interior Handrails KeelHaulin Gear & Maintenance 10 12-05-2007 01:20 AM
