Old 10-02-2010
jadkkd is on a distinguished road
shaft vs. saildrive
Have been hearing several concerns about boats with a saildrive sytem for power, that the saildrive is a a maintainance concern especially in the waters of New England. Electrolysis is a major concern
Old 10-02-2010
deniseO30's Avatar
Lies about her age
just a big hole in the bottom of the boat. (imho)
Old 10-02-2010
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Why would the waters of New England be an issue? How are they any different than anywhere else?
"Clean bottoms are FastBottoms"
Old 10-02-2010
I'm certainly not an expert and am the last person to know but electolysis a bigger issue on the east coast?
Old 10-02-2010
Fstbttms's Avatar
No. Saltwater is saltwater. We are not talking about some force of nature on a regional scale. Corrosion issues are generally due to a problem aboard the specific boat in question and have nothing to do with where in the world the boat lives.
Old 10-02-2010
ok but would the corrosion be a biiger problem on the saildrive?
Old 10-02-2010
Fstbttms's Avatar
Saildrive legs can corrode, but properly maintained and protected by zincs, they are no more prone to this than shaft/prop arrangements.
Old 10-02-2010
Da Most Educated Red Neck
rockDAWG is on a distinguished road
Agree. THe proper use and maintained are the key. I believe SD is a viable alternative. As we gain more experience on SD, it will replace the shaft. I hope the engineers are working on one that can rotate from side to side (left and right). Bow truster will be replaced.
If the hull is properly designed and the SD is properly installed. A big hole at the bottom of the hull is my least concern.
Starting 2012 sailing season: Done with the timeshare boat.
Old 10-02-2010
Omatako's Avatar
Omatako will become famous soon enough
Nahh - SD can't swim nearly fast enough!
Arthur C. Clarke
Old 10-02-2010
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
Someone I know and respect who has a great deal of experience with sail drives recommends not using the water intake that is part of the sail drive. Rather, seal the intake with epoxy and fill the leg with antifreeze mix. Then get your cooling water through a conventional through hull. Not having sea water on the inside of the leg will dramatically reduce the possibility of corrosion - and yes, you still need to keep a close eye on your zincs.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Shaft Coupler to Shaft attachment dhornsey Gear & Maintenance 20 06-30-2008 02:07 PM
C-27 shaft packing seized on shaft? CellNav Gear & Maintenance 1 05-08-2007 02:55 AM
Shaft replacement or ''the shaft''? foxglove Gear & Maintenance 4 08-18-2006 11:16 PM
OMC saildrive maestro Gear & Maintenance 8 04-01-2004 09:29 AM
OMC saildrive Jim Malcolm Gear & Maintenance 0 06-20-2002 02:12 PM
