10-04-2010
I would certainly look at cleaning off the rust and getting down to good metal and re-galvanizing all the gear, if it is in good enough shape. That would give it some protection against future corrosion. Rust is not a protective corrosion layer, unlike the corrosion that forms on Aluminum or some other metals. Removing it and protecting the good metal underneath is really the way to go.
BTW, you say you have 12' of water..is that at low tide, high tide or mid-tide? If that is at low tide, then the 20' of 1/2" chain is probably a bit short, since you're likely close to 1:1 scope on the upper chain at high tide.
