Old 10-03-2010
Still learning!
Magic1 is on a distinguished road
Pss Shaft Seal
Own 2002 Catalina 400 with the "old" low speed PSS shaft seal. has worked flawlessly for 9 seasons. During a 10 day cruise last week on the Chesapeake Bay, discovered the PSS shaft seal leaked (badly) between the bellows and seal plate whenever RPM advanced above 3000 or "jam" throttled from idle to around 2600. Anyone else had this problem and if so, what did you do to correct?
Tim Leighton
S/V "Magic"
Chesapeake Bay
Old 10-03-2010
deniseO30's Avatar
Lies about her age
The bellows may have lost some of it's resilience, you may want to replace that or possibly just move the collar back more. Also, make sure you "burp" it and make sure there isn't anything like algae between the surfaces. I think "whip" in the shaft would make it leak also. Hope this helps. I have one my boat. love it!
Old 10-03-2010
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
The bellows would be my guess. You may want to throw on a shaft clamp while your at it if you don't already have one, see here: McMaster-Carr
BTW, whens the last time you checked your alignment?
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 10-03-2010
jrd22's Avatar
Courtney the Dancer
Can't remember what the recommended replacement time is for the bellows, but I'm guessing it's less than 9 years.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 10-03-2010
Gene T's Avatar
Gene T is on a distinguished road
I agree with Denise that you should retention the collar. There is a set amount of compression (movement of the collar) that depends on shaft size. The people at PYI could probably tell you how much it is.
I think the recommended replacement is 10 years (that may be the non official recommendation).
If your engine alignment is off that could cause severe movement at the seal too, so I would check alignment.
I would also make sure your prop isn't bent or that you have some line wrapped around it causing the vibration.
Gene
Currently in Long Beach, CA
Old 10-03-2010
T37Chef's Avatar
for some reason I recall it being 7 years, surely a inquiry will help you...PSS Shaft Seal: The world’s leading dripless seal.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
Old 10-03-2010
Maine Sail's Avatar
Tim Leighton
S/V "Magic"
Chesapeake Bay
Your motor mounts are likely getting worn and allowing the motor to move forward under load OR the stainless rotor has moved or become loose. If you have a 2002 boat the bellows is due anyway so might as well upgrade to the vented PSS. They will sell you a new bellows and the vented carbon disk for quite a reasonable cost.
In the meantime:
1- Mark the shaft where the stainless rotor is now using a sharpie marker or electrical tape.
2- Remove the set screws on the stainless rotor, there should be TWO in each hole and compress the bellows with the stainless rotor perhaps another 1/4" beyond where it is now. Run up to full WOT RPM and make sure it is not leaking. If it is and shaft is true etc. then move it back another 1/8" to 3/16" and try again.
Two Set Screws:
3- Install NEW set screws. PYI will ship them to you. DO NOT re-use the old screws!
1 Use vs. New:
This should solve your problem but you may want to investigate your motor mounts.
Oh and as added safety measure to prevent the stainless rotor from moving have PYI send you one of their new "clamp collars" as well.
______
-Maine Sail / CS-36T
Old 10-04-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
What is the purpose of the vent?
Old 10-04-2010
Maine Sail's Avatar
To keep lube water inside the seal and prevent it from becoming an air trap, over heating and squealing. On many boats a quick thrust of reverse will send air bubbles up onto the shaft log which have no way to get back out. Also sailing in rough weather can create trapped air up inside the shaft log. Some boats are worse in this regard than others. My old C-36 needed to be burped about every three week to get the air out, a royal PITA..
______
Old 10-04-2010
olson34 is on a distinguished road
Lightbulb
I spoke to a PSC rep at a show several years ago about the dropping of the original non-vent seal and also the life expectancy of the bellows.
He said that there was always some chance that someone would buy the non-vent version (for boats motoring under 12 kts) and somehow thru misuse or resale it would wind up on a too-fast boat. Easier to just consolidate to one model, altho not necessary on our sailboat.
Ten years is about right to replace the bellows, altho they can normally go years longer. So if we have a haulout scheduled near that time interval, just replace it then.
"Not for attribution, but this bellows replacement time was specified by the liability lawyers and not the engineers." (or words to that effect.)
We had a PSS seal installed in about '95, and never had a bit of trouble. After talking with the rep, replaced the bellows at a haulout for a bottom job about a decade later.
A dry bilge is nice.
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Shaft Seal Failure - What do you do? dhornsey Gear & Maintenance 24 01-31-2009 08:11 AM
Lasdrop Shaft Seal...Help? T37Chef Gear & Maintenance 4 03-27-2008 10:01 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 11:03 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
