10-04-2010
Originally Posted by outdoorsman37
Hello. i bought a 1979 pearson 32 and it has a damaged bow. the anchor roller seemed to hit something and tore up the bow deck fiberglass. i can post a picture later but basically it looks like a triangular section of the bow deck has been ripped upward. if you have any recommendations on how to fix it I would really appreciate it. it looks like there is a wood core to the deck.
Without photos or seeing the actual damage, there's little we can say about repairing it. The bow is usually a fairly critical area, since the forestay chainplate is attached there. Most decks are cored, and the Pearson is probably balsa cored.
I hope you got a really good price on the boat, since it sounds as if it has some relatively serious issues. I also hope you were wise enough to get the boat surveyed. If you did get the boat surveyed, I would be curious to hear what issues the surveyor found on it. If you didn't get the boat surveyed, it might be a wise idea to do so, so you can at least get an idea of what you need to do to make the boat seaworthy.
also, the mast where it goes through the deck is held in place by wood shims (trangular). is this supposed to be that way? if there is a part that i am missing please tell me and i will buy it? the area is covered with a rubber cover but the wood shims seem rigged. any comments would be greatly appreciated thanks!
Rob
Yes, it is supposed to be that way, as Denise said.
