Old 10-04-2010
Weserin is on a distinguished road
How to drop mast?
I have a 27' bayliner buccaneer sailboat. I have owned it for just short on 4 months. And I want to drop the mast for the winter. I have read the instruction manual, however not very clear on the instructions. Can someone give me better instructions on how to drop the mast.
Old 10-04-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
It would help somewhat if we knew if a Bayliner buccaneer was a deck stepped or keel stepped mast (I'm too lazy to look it up at the moment).
The path of least resistance and most cash outflow involves a crane which can pull the mast off the deck and will set you back several hundreds of dollars. Other options involve a nearby bridge that has enough height to help you lift it off but I wouldn't suggest that right now as your mast could weigh as much as 200 - 300 #'s or more.
Old 10-04-2010
Patient's Avatar
Patient is on a distinguished road
What Caleb said.
Could you explain your situation a bit more in detail?
Where are you located?
Where is your Bayliner located?
Is it in the water, on a trailer or on stands?
After a quick google image search I think you might be able to jury rig something that could be safe if you are not near a crane, but if always better to just let someone do it in a way thats safe anyhow.
Old 10-06-2010
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Agree. My Catalina 22 mast was stressful enough to lower using an A-frame device. Hire a crane (cheaper an marina?). If the boat will be on land near the water, consider not lowering the mast every year.
Old 10-06-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Merit 25 # 764 "Audrey"
Old 10-06-2010
jjablonowski's Avatar
jjablonowski is on a distinguished road
I'm assuming you have a deck-stepped mast.
Go to YouTube and get some various ideas.
Start here: YouTube - Stepping Mast on a Catalina 25
Old 10-06-2010
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
Where are you located? I'm doing one saturday in Maryland...you can come help...haha.
I looked into cranes and found them to be pretty expensive. Someone recommended hiring a sign company. I found about 4 of them in my area that were willing to help. They're charging $275.
My complete refit is taking completely too long!
how to drop a mast on a soling? Ascension General Discussion (sailing related) 12 10-27-2010 12:22 PM
Sturdies Bay-drop off monkeymom Pacific Northwest & Alaska 4 09-08-2010 04:39 PM
westerbeke rpm drop flyin2009 Diesel Engine Forum 2 08-21-2009 06:06 PM
Drop jib and come in under mainsail? mkrautha Learning to Sail 10 06-10-2008 03:18 PM
drop keel rois mara Gear & Maintenance 0 05-03-2001 04:10 AM
