Old 10-04-2010
Waltthesalt is on a distinguished road
Cal 29 shaft
I'm repowering a Cal 29 and need to order a prop. Does anyone know if the Cal-29 uses a tapered shaft?
Old 10-05-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
Most shafts are tapered at the prop end. You only need to know the shaft diameter to order as the tapers are standard. Need prop diameter and pitch of course. And RH or LH.
Old 10-05-2010
tommays's Avatar
It should be the same 1" single taper shaft (prop end) with a lenth change
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Got the shaft out, what to look for? preservedkillick Gear & Maintenance 8 04-09-2010 05:31 PM
shaft log huguley3 Gear & Maintenance 6 11-02-2009 06:53 PM
Shaft Coupler to Shaft attachment dhornsey Gear & Maintenance 20 06-30-2008 02:07 PM
C-27 shaft packing seized on shaft? CellNav Gear & Maintenance 1 05-08-2007 02:55 AM
Shaft replacement or ''the shaft''? foxglove Gear & Maintenance 4 08-18-2006 11:16 PM
