Sensibulb Caution - Page 3 - SailNet Community
post #21 of 34 Old 10-09-2010
dhays's Avatar
Originally Posted by helmsmatt View Post
Wait about 6 months and take the pics again.
No power dissipation (heat sinks) or temp control on the LEDs.
They will fade/degrade.
You wasted your money.
You can't mount a high power LED on an FR4 PC board with no temp compensation or ability to dissipate heat without adversely affecting the LED.
You will exceed the junction temps of the device over time and the LED's performance will degrade.
We will see how it goes. This is a work in progress. Keep in mind that I'm not a live-aboard and will only be using the boat for weekends and a couple week-long cruises for the next couple years. I'll definitely update as I notice any changes.
How long did these particular bulbs last for you?
Keep your halogens. You will want to use them again when you LEDs aren't putting out enough light to light to read by in a few months.
Yup. I kept them all to use for replacements in case of failure.
Paying $40.00 once is far cheaper than paying $16 three times.
I agree.
Good Luck
Thanks.
Dave
47⁰20'11.7" N
122⁰35'20.8" W
M/V Kinship, North Pacific 43
Formerly
S/V Legacy, Catalina 400 MkII, Hull #328
dhays is offline
post #22 of 34 Old 10-10-2010
CD—
Could it be that you just got two bad Sensibulbs? Are they from the same manufacturing lot? I seriously doubt that Sensibulb would put out a bluish tint bulb if they could avoid it in any way, given their reputation in the marketplace.
sailingdog is offline
post #23 of 34 Old 10-11-2010
eMKay's Avatar
I just got back from the show, the new bulbs definitely do NOT put out a "blueish" hue. They have one of the new ones right next to a halogen bulb, and if you look at them straight on, the sensibulb is a little whiter (which to me is good!) and if you put your hand under them, the light reflecting off is nearly identical. I have some pictures I took but can't post them until I get home (wednesday) One thing is for sure, that single LED is very bright and puts out a very smooth and even light, I really like them and will be putting them in my boat
Technician, RCR Yachts Buffalo.
eMKay is offline
post #24 of 34 Old 10-12-2010 Thread Starter
Best Looking MALE Mod
Cruisingdad's Avatar
Hi Guys,
Sorry for the delay. Had other more pressing matters.
Well, I will show you the pics I took. I tried to show them side by side so you could see the difference. First a pic showing the difference between the two products:
To the left is the old sensibulb, to the right is the new one. THe new bulb has a single LED, the old has two.
Now to the difference. This first pic is a sensibulb compared to a halogen. THis is the new sensibulb. The sensibulb is to the right. Now please understand that it is hard to show color like this in a picture... it was the best I could do.
THis next pic is a pic of the new Sensibulb against the old sensibulb. The new sensibulb is to the right.
To me, at least in person, there is a distinct difference. It is harder to show it in a picture. Sorry. But maybe you can see what I am talking about? Also, when it reflects against the wood or other shiny surfaces, it becomes more apparent. If it reflects against dull sirfaces, it becomes less apparent. Because all of our wood is glossy, it may be more apparent in our boat than other boats.
Now, I want to say several things in all fairness. First, this is MY (and my wife and kids) opinions. You may not think this looks blue at all. You may put this bulb in your boat and think it looks green or pink. I am not being a smart A, I am simply saying that all of our eyes are different and we may see colors differently. But to us, on our boat, it is BLUE. Not white. Not yellow. It is BLUE.
Second, and this may be more important, I think this BLUE is much more apparent when it is mixed. I did not want to go out and spend hundreds of dollars on LED's and pull out perfectly fine Halogens. So I am replacing them one at a time as the halogens burn out. When I mixed the old Sensibulbs and the halogens, I could not tell any difference. When I mixed the new Sensibulbs and Halogens (and against the old sensibulbs) there was a sharp contrast. As such, for anyone that is planning on pulling out all their LED's and replacing them all at the same time, you may not notice a big difference. MAY NOT NOTICE.... I must say again. We tried simply putting the new ones in our center lights and we still felt it was blue... but not quite as noticeable as when the other lights are on.
SO there you go. I hope this helps. I still think Sensibulb makes a superior products, but I doubt I will be investing in them any more and will save my money until I can find more yellow bulbs or I will stick with halogens because I do not like blue. It looks too much like a flourescent to me (us).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #25 of 34 Old 10-12-2010
Irrationally Exuberant
I can definitely see it in your pics, CD. Maybe it would be worth sending a picture to the Sensibulb folks to see if your results are what they would expect. If not, could be a bad batch.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #26 of 34 Old 10-12-2010
Maine Sail's Avatar
It's really tough to tell from the pictures but I would have to say the ones I have don't seem that much off in a direct comparison?
What I DO notice though is just how much WIDER the beam width is on the new model when compared to the old ones. That spread is a fair number of degrees wider than the older models and why I really prefer them over the older models in overhead lighting fixtures.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #27 of 34 Old 10-12-2010 Thread Starter
They are also brighter (the new ones) than the older sensibulbs. At least they appear that way to me. But still blue. Whether dull blue or bright blue, it is still blue. And quite candidly, I did not tell much of a difference between the halogens and the old sensibulbs as far as brightness. I would honestly say that when you put old sensibulbs in (mixed with halogens), it would be hard to tell a difference except that maybe the sensiblubs were brighter and sharper. But whatever... if I can't get anymore, it is like crying over spilled milk.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #28 of 34 Old 10-13-2010
eMKay's Avatar
Here are pics I took of the new bulb at the show next to a halogen, I'm very impressed with these, if they hold up over time they seem well worth it...
It "looks" dimmer, but that's probably because it doesn't shine nearly as much light on the fixture. It doesn't look bluer, it does look more white.
Now, with my hand under both the light output and color look nearly identical, matter of fact the halogen on the right looks whiter to me...
EXIF data to show no color balance monkeying going on, there was also no post processing other than resizing...
Camera Maker: Canon
Camera Model: Canon EOS DIGITAL REBEL XTi
Image Date: 2010:10:11 14:26:26
Focal Length: 18mm
Aperture: f/3.5
Exposure Time: 0.050 s (1/20)
ISO equiv: 200
Exposure Bias: none
Metering Mode: Matrix
Exposure: program (Auto)
White Balance: Auto
Flash Fired: No
Color Space: sRGB
eMKay is offline
post #29 of 34 Old 10-13-2010 Thread Starter
Camera Maker: Canon
Focal Length: 18mm
Aperture: f/3.5
ISO equiv: 200
Exposure Bias: none
White Balance: Auto
Flash Fired: No
Color Space: sRGB
I am beginning to wonder if I have a bad set?? Do you see the color difference in my pics? Very different from yours. ANd again, I want to stress, it is hard to show blue in a pic so what you see as blue is REALLY blue (at least to me).
I will reach out to the sensibulb folks with my pics.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #30 of 34 Old 10-13-2010 Thread Starter
I have spoken with Scad again this morning. I have sent them the pics. We may end up exchanging them for the older set. I will let everyone know how it turns out.
They were very nice about this over the phone... and a bit perplexed because I seem to be the only person that has brought up this issue.
Sailnet Moderator
My Website:
Follow My Blog at:
MPPT Solar Caution ... wind_magic Electrical Systems 8 02-21-2010 08:10 PM
New Lighting Fixtures with Sensibulb LED's Willis Gear & Maintenance 4 03-23-2009 01:00 AM
Product Review - Sensibulb !!! Maine Sail Gear & Maintenance 6 08-14-2008 12:00 AM
Caution using wire reinforced water hose NauticalFishwife Gear & Maintenance 3 04-09-2008 09:21 PM
Cruise Report: Salem to Charleston. Caution: Long kptmorgan04 Cruising & Liveaboard Forum 9 10-23-2007 11:04 PM
