Old 10-09-2010
stiffwind's Avatar
s/v Black Prince
stiffwind is on a distinguished road
Adjusting Forsheda line snubber
Anyone have experience adjusting those wrap around rubber line snubbers? I have the snubbers on some 3/4 dock line and the snubber seems nearly impossible to move to a different location on the line because the line is so tightly stretched through the end feeds?
Old 10-09-2010
genieskip is on a distinguished road
I used them at one dock some years back and found that if you use the line size recommended for a particular snubber it becomes jammed and unmovable.
My solution was to use line one or two sizes smaller than the recommended size or conversely use a snubber larger than the line you think is safe for the particular situation. My boat called for 1/2" line and after a while I used snubbers for 5/8' line and had no trouble (and the snubbers lasted longer)
genieskip
Northeast
J40
1991
Old 10-09-2010
stiffwind's Avatar
s/v Black Prince
sounds easy enough, but my current problem is moving the darn thing now that is on the line....the snubber was already on the lines when I purchased the boat.
Old 10-10-2010
Work at it with a marlinspike and needle nose pliers and a good deal of determination and you can work the line free of it.
genieskip
Northeast
J40
1991
Where Can I get this type of snubber? KindOfBlue Gear & Maintenance 1 09-13-2009 05:58 PM
Dockline failure from snubber argofred Gear & Maintenance 24 07-24-2009 05:13 PM
Attaching snubber to chain... pdqaltair Seamanship 29 03-23-2009 12:52 AM
What kind of anchor snubber? soulfinger Gear & Maintenance 51 12-23-2008 06:12 PM
Snubber Line tsingtao Seamanship 16 02-22-2008 02:31 PM
