Old 10-09-2010
stiffwind's Avatar
s/v Black Prince
stiffwind is on a distinguished road
Solid boom vangs
How important is having a solid boom vang vs. the old block and line vang, on a 37' cruising boat
Old 10-09-2010
Gene T's Avatar
Gene T is on a distinguished road
A solid vang can support the boom so you don't need a topping lift. You then hook your halyard to the end of the boom when not using the main. A boomkicker can also do this and is another option.
Gene
Currently in Long Beach, CA
Old 10-09-2010
On that size boat I'd say a solid vang is very worthwhile.. Gerhauer seems the best deal on these nowadays.
As Gene says, no need to have a topping lift flailing about chafing the leech of the main and interfering with the trim (when you forget to ease it).. no boom dropping into the cockpit or onto the dodger (when you forget to set it!)
For optimum control on a larger boat, hydraulics are really the ticket, but you're likely not racing and may not be able to justify the buy-in.
1984 Fast/Nicholson 345
Old 10-10-2010
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
The beauty of a solid vang is that when you reef the boom doesn't come down and hit you in the head.
Rick I
Toronto in summer, Bahamas in winter.
Old 10-10-2010
Even if you go with a solid vang, I wouldn't get rid of the topping lift. A good topping lift can substitute as a backup main halyard, can be used for hoisting someone aloft, etc.
Old 10-10-2010
That's true, but it needn't be flopping around along the main, it could be stowed elsewhere until needed for any of these various backup plans... I'm not sure I'd be wanting to go aloft on some of the 'topping lifts' I've seen rigged.... and still others are fixed with a small adjustment at the boom - which wouldn't serve those purposes..
Boom Vangs on Cats MovementSailing Sailboat Design and Construction 3 04-28-2009 07:57 AM
Rigid Vangs - Spring Loaded vs. Hydraulic daniel9331 Gear & Maintenance 4 10-16-2008 03:49 PM
broken boom mid-boom sheeting problem? somedaypam Gear & Maintenance 15 10-23-2007 05:22 PM
Boom Vangs kikisteve Gear & Maintenance 10 01-09-2002 08:02 PM
Boom Vangs SailNet Racing Articles 0 10-04-2000 08:00 PM
