Old 10-09-2010
kiwisailor is on a distinguished road
Mounting a compass on a steel yacht
Hi , I have a Bruce Roberts 38 that was modified by a mad engineer so she has a steel deck ,cabin and pilot house . This is great for strength , no leaks etc but pretty hard to mount a compass on . I've heard you need to mount any compass 600mm from any steel , and that you can approximately swing it and adjust with the magnets inside . Any one had any experiance with this as I really want a non electronic backup (ie not a fluxgate) to my GPS. Ive just purchased a second hand Heath compass so if anyone has experince with those let me know
Cheers
Old 10-10-2010
IIRC, the compasses designed for installation on steel boats have to have compensators. You can't install just any compass on a steel boat. They usually look like this:
If your compass doesn't have the two compensators, then you're going to have to buy a different one.
Old 10-10-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Not absolutely correct SD. Raven is steel, does not have a compass as you illustrate but it does have lumps of metal inside that can be moved. Yes , what you show is called a 'steel boat compass' but it seems other models work also.
I'd think a Compass Adjuster would be the person to ask regarding a particular unit.
Which reminds me I need to get hold of one.
Old 10-10-2010
sailor50 is on a distinguished road
Lumps of metal that can be moved? I thought these we balanced!
Old 10-10-2010
tdw's Avatar
tdw tdw is offline
were balanced ?
quite possibly... I'll be straight with you.....all this compass adjustment business is a black art to me. All I know is that I have a steel boat that has a compass that is is relatively accurate, has been installed for twenty odd years and doesn't have the ourtigger balls.
Mounting a compass on a steel Yacht kiwisailor Introduce Yourself 1 10-11-2010 03:26 PM
Mounting Chartplotter Near Compass? MedSailor General Discussion (sailing related) 8 06-30-2009 06:19 AM
New Compass mounting... Iflyka200s Gear & Maintenance 3 06-25-2008 09:04 PM
compass for autopilot on a steel boat Kater Gear & Maintenance 18 02-29-2008 09:55 PM
mounting a compass... groundhog Gear & Maintenance 12 10-03-2006 11:58 AM
