Old 10-11-2010
Fidelity is on a distinguished road
Forespar Man Overboard Pole - Sinks
This may be a no brainer for some - however, we were hosting MOB practice with a weighted dummy - and utilizing all of our equipment and styles i.e. life sling, figure 8, quick stop and new MOB pole.
It sunk! to where only the flag showed (due to the depth of the bay) We anticipated it coming back up and it never did - practiced the drill several times - are we stupid - the instructions say nothing - and before we contacted forespar - I thought I would research from actual users.
We checked our float and it has a perfect hole in it - as does our friends' pole.
Can someone enlighted us?
Thanks.
Old 10-11-2010
erps's Avatar
the pointy end is the bow
We replaced ours this year because the old one sunk. I was a little dismayed to say the least. Those things aren't cheap.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 10-11-2010
jackdale's Avatar
jackdale will become famous soon enough
I believe that the hole is for adding foam to the float. If the foam degrades, it may fall out. Could that be the problem? I have used a lot of these poles. but have never had this problem.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 10-11-2010
Thanks. BTW our pole was brand new -
Old 10-11-2010
erps's Avatar
In our case, the weighted end developed a small crack in the bottom which allowed water to enter the hollow fiberglass pole. The vinyl cover over the bouyant bulb also degraded some, but the floatation material was still there. Looking at it, it seemed it should still float but when we put it in the water to test it, it sunk. That was quite a surprise. If it wasn't my pole, I would have even thought it was funny in an ironic sort of way. I wasn't laughing though.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 10-11-2010
jackdale's Avatar
It was fortuitous that neither of you had to use the pole in an emergency.
Old 10-11-2010
mitiempo's Avatar
With the orange float?
Brian
Old 10-11-2010
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
unF*@&ingbelieveable.
Old 10-11-2010
erps's Avatar
Yes
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 10-12-2010
Forespar - Excellent customer service - they are sending a new pole/float to us today - to arrive by week's end - Monday at the latest. Just before we go offshore!
Forespar Marelon winches bobmcgov Gear & Maintenance 6 08-09-2010 10:08 PM
Forespar TruPlug kwaltersmi Gear & Maintenance 4 04-22-2010 03:45 PM
KUDOs to the folks at Forespar! dave6330 Gear & Maintenance 0 12-08-2009 05:06 PM
North Pole. Pete Goss puts Playing for Success Charity in Pole position @ BYM Sailing News NewsReader News Feeds 0 04-20-2006 04:15 AM
RE: MAN OVERBOARD POLE MOUNT sailstactics Gear & Maintenance 2 08-05-2003 05:29 PM
