head troubles...... - Page 2 - SailNet Community
post #11 of 22 Old 10-12-2010
T37Chef's Avatar
Just go and buy on of these, they are inexpensive, work, and a rebuild kit is easily found and easy to install.
JABSCO Twist'n'Lock Compact Manual Head at West Marine
and the service kit: JABSCO Jabsco Service Kits & Parts for Manual Toilets at West Marine
Shawn
T37Chef is offline
post #12 of 22 Old 10-12-2010 Thread Starter
that is just the one i had in mind.....i did have some luck with getting the old one to work ...but it is on its last leg.....but i did get the lines cleared and now contain... cleaner....... water..... replacement is on the list...well the old gal is starting to clean up pretty good.......tomorrowi i need to find the local yanmar dealer........i am in st pete fla. anyone know where the yanmar dealer is here?......thanks once again..
twisted23 is offline
post #13 of 22 Old 10-13-2010
remetau's Avatar
The big one: Welcome to Mastry Engine Center
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #14 of 22 Old 10-13-2010
Instead of buying a Jabsco, which is a pretty lousy unit by all accounts, I'd get a RARITAN PHC/PHII LBA unit, which is about the same price as the full size Jabsco Twist & Lock and only a little more money than the Jabsco Twist & Lock compact head.
The LBA unit re-uses the bowl off your existing head, and basically gives you a brand new (except the bowl) Raritan PHC or PHII head unit. This head unit is considered one of the best inexpensive manual head units by Peggie Hall, and is a far better unit than the Jabsco.
sailingdog is offline
post #15 of 22 Old 10-13-2010
T37Chef's Avatar
The Raritain is about the same price? When I looked they were almost double the Jabsco? And what makes the Jabsco unit "louzy"...Ive had mine for about three years and it works just fine, probably will need to rebuild it in a year or two but just about any head will need that, no?
No sure how accurate these comparative prices are for the Raritan but...
Raritan PHII and PHEII Marine Toilets and Accessories RAR-PHII Standard 12V Toilet: Compare Prices, View Price History and Read Reviews at NexTag
Edit: From Defender
Jabsco New Twist 'n' Lock Manual Marine Toilet
Raritan Compact II Manual Toilet
For another $130 +- the Raritan is most likely the better buy, of course you could just buy the coversion kit as SD mentions, PHII Pump Assembly
Shawn
T37Chef is offline
post #16 of 22 Old 10-13-2010
T37Chef—
The twist-lock mechanism is a hackneyed way of solving a non-issue in a better designed head. The Raritan PHC LBA unit is only $220, and not the same thing as the pump you've pointed out. The Jabsco head you're pointing out is $175. For the $45 price difference, I'd recycle the bowl and get the Raritan instead.
A brand-new Raritan PHC head unit is $454...so for $220, you're getting the equivalent of a $455 head that is probably one of the best designed in the business and recommended by Peggie Hall....BTW, the RARITAN Compact II you linked to is not the same thing or in the same league as the PHC/PHII... totally different beasties.
Edit: From Defender
post #17 of 22 Old 10-13-2010
Best Looking MALE Mod
Cruisingdad's Avatar
Nah, don't listen to any of their advice.
You need to buy the Jabsco Quietflush electric head. Best head I have ever crapped in. Plus it has a auto-wipe function: just hold the bowl-fill button down while sitting there. My 6 yo showed me that one. Ahh.... the joys of parenting on a boat.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #18 of 22 Old 10-13-2010
T37Chef's Avatar
Thanks for the clarification SD, I don't get the twist and lock thing on the jasbco either. I guess I'm just sayin the Jasbco is inexpensive and does the trick rather well IMO, maybe when the pump breaks I'll replace it with the Raritan part LOL
Shawn
T37Chef is offline
post #19 of 22 Old 10-13-2010
T37Chef's Avatar
Actually Brian is correct, as he certainly gives his head a hefty work out, we all know why!!! Bawahahahahahaha
Shawn
T37Chef is offline
post #20 of 22 Old 10-13-2010
Glad to help Shawn.
Maxsea and USB GPS troubles FollySailor Gear & Maintenance 2 07-08-2010 08:11 AM
dickinson chesepeak troubles willdadd Gear & Maintenance 1 03-11-2009 01:28 AM
overcoming some VHF and GPS troubles CaptainRonandAshley2 General Discussion (sailing related) 1 08-27-2008 05:38 AM
More 12v Troubles and ?'s Perithead Gear & Maintenance 7 11-26-2007 01:33 PM
Starting troubles raybies Gear & Maintenance 4 05-14-2003 09:24 AM
