Old 10-12-2010
LakePirate's Avatar
LakePirate is on a distinguished road
Should I be concerned about the house battery
Both batteries (a group 24 starter and 27 house) showed 100% charge on the meter before leaving the dock. After only about an hour and half of sailing with only the gauges on I went to start the motor with the switch on just the house battery and nothing. Ran down and switched to all and it fired right up. I know the group 27 isn't designed to be a starter battery but figured it would have enough to at least spin the motor a little. My question is since it didn't do anything should I be considering replacing the batteries?
When a Woman says - Go Ahead: This is a dare, not permission. Don't Do It!
Old 10-12-2010
night0wl's Avatar
night0wl is on a distinguished road
How much amperage does your starter draw to turn the engine over? Realistically, that size battery bank should have enough juice to do the deed...really, the type of battery form factor (a Group 24 or Group 27) isn't salient to the discussion.
The TYPE of battery, however, is. Are these Group 24 or Group 27 starting batteries....flooded deep cycle....AGMs....? How do you keep them charged when not in use? Also - a simple battery load test will reveal if the batteries are any good. I've had many batteries show strong voltage (12.8+ Volts) only to just fall to 10 V and lower (discharged) when the slightest load is put on them. That just means the battery is shot.
More info would be useful to diagnose your battery issue. But at a minimum, I would recommend a battery load test. Most auto repair stores will do this for you.
S/V Jendai
Beneteau 343
Old 10-12-2010
LakePirate's Avatar
The 24 is a starter and the 27 is a deep cycle. I didn't have a volt meter with me but I'm guessing since the batteries are 3 years old it's time to replace.
Old 10-12-2010
Gene T's Avatar
Gene T is on a distinguished road
Have you checked the electrolite level?
Gene
Currently in Long Beach, CA
Old 10-12-2010
mitiempo's Avatar
You should be able to start a small gas or diesel engine (under 40 hp or so) with any group 27 battery in good condition. Even a deep cycle battery.
3 years isn't long for batteries if charged properly.
You say they showed 100% charged by the meter. What kind of meter?
Also if one battery is dead best to switch to the other battery, not to both. Combining a good with a dead battery can drain the good battery.
It sounds like the battery might be shot.
Brian
Old 10-12-2010
Irrationally Exuberant
arf145 is on a distinguished road
I would guess that your meter is a volt meter. Batts can show 100% (or close to it) in terms of volts while being fairly dead in terms of capacity--as nightowl said.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 10-12-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
A volt meter will not tell you much of anything in terms of how good the battery is, just that it's charged.
Hey, can one of you guys pass me a crab?
Old 10-12-2010
CapnRon47 is on a distinguished road
House vs starter battery
LakePirate,
It may also depend on how the boat is wired. I have 4 house batteries but I cannot start the engine from them I have to either use the starter battery or have them all on both.
Old 10-12-2010
mitiempo's Avatar
CapnRon
That makes no sense. If "both" selects the house batteries they must be connected to the post the start battery is not connected to, either 1 or 2.
Brian
Old 10-13-2010
What kind of meter are you using? IF it is just a voltmeter, it is USELESS for determining state of charge for the most part. For a voltmeter to give any reliable reading, the batteries have to be sit undisturbed, without loads or charging for a fairly significant period of time, usually 10+ hours, so that you're actually reading the true state of charge, rather than surface voltages from charging the batteries. A Hydrometer can show you the real SOC on a wetcell battery.
Do you have wet cell batteries? If so, when was the last time you checked the electrolyte levels in them. If the levels are low for any significant period of time, you can damage the plates and then the battery will lose significant amounts of capacity, although the voltage readings won't change much.
Also, how are you charging the batteries? Wet cell batteries like to be on a smart, three-stage charger. They also will self-discharge over time, faster with higher temperatures, so charging them on a regular basis is a good idea.
House Battery Selection ISLANDAH Gear & Maintenance 22 06-21-2007 10:12 PM
Best House Battery bob1956 Gear & Maintenance 3 04-19-2007 11:24 PM
Starting Battery vs. House Battery GarrettK Gear & Maintenance 18 10-26-2004 10:58 AM
Starter or House Battery? rrobar Gear & Maintenance 2 12-30-2003 03:56 PM
House battery capacity wwilson Gear & Maintenance 7 03-07-2001 08:06 PM
