Bottom Paint - SailNet Community
post #1 of 3 Old 05-04-2003 Thread Starter
Wandering Aimlessly
PBzeer's Avatar
Bottom Paint
Have just repaired gouges in hull below waterline and was going to apply Petit Trinidad (what is on now) to the repaired areas. When checking on it, it seems to indicate a 60 day wait before putting back in the water. Anyone have any experience with this product that can tell me for sure about drying time? Am thinking at this point, will just let it go till end of season, if that is the case (on a lake, not salt water).
Fair winds,
John
PBzeer is offline
post #2 of 3 Old 05-04-2003
Bottom Paint
Bottoms /w "Trinidad" antifouling should be launched within 8 - 24 hours of application (depending on temperature - 8 hrs @ 90 Deg.F, 16 Hrs @ 70, & 24 Hrs @ 40).
Epoxy Barrier-Coats can certainly be overcoated /w antifouling after a full cure is achieved (normally between 1 to 4 days). Interlux ("Interprotect'') advises antifoulong overcoat between as little as 5 - 9 hours.
Regards,
Gord
GordMay is offline
post #3 of 3 Old 05-04-2003 Thread Starter
Wandering Aimlessly
PBzeer's Avatar
Bottom Paint
Thanks Gord.....finally found the Petit website...under Kop-Coat and got the same info there. Appreciate the info though
Fair winds,
John
PBzeer is offline
Cruiser''s Bottom Paint??? staceyneil Gear & Maintenance 2 03-28-2004 11:06 PM
Bottom Job question(s) rookie00 Gear & Maintenance 19 03-19-2003 03:01 AM
Veridian Bottom Paint flysurfer Gear & Maintenance 0 07-26-2002 01:34 PM
Bottom Paint fishclan Gear & Maintenance 3 05-04-2002 06:23 PM
To Paint bottom or not? rightlife Gear & Maintenance 0 01-02-2001 08:40 PM
