traveller - Page 2 - SailNet Community
post #11 of 20 Old 10-18-2010
Here are some photos I took yesterday. I took the pictures through the door the previous owner cut in the bulkhead. You can see the tips of the screws poking through the bottom of bridgedeck. I believe there is a tapping plate embedded in the bridgedeck. It would be pretty well impossible to put nuts and washers here without removing the engine first!
I had a jib track pull out of the deck. All the screws were self tappers except the ones at the end. There I found a stainless plate embedded in the deck. It appears that is how the mainsheet track is fastened too.
So this suggests two ways to fix this. First drill out the old threads to the next tap drill size and tap new threads in the plate. Then drill out the traveler holes and countersinks for the new larger screws.
The second way would be to install thread inserts. See McMaster-Carr
part # 97120A220 as an example. You drill out to the tap size for the insert, tap the hole and install the inserts, then use the same bolts as previously.
Hope this helps
Gary H. Lucas
GaryHLucas is offline
post #12 of 20 Old 10-18-2010
Hope this helps
Gary H. Lucas
Okay, so no pictures are attached WTF?
post #13 of 20 Old 10-18-2010
I wouldn't use threaded inserts, since the potential for galvanic corrosion is much higher...
sailingdog is offline
post #14 of 20 Old 10-19-2010 Thread Starter
what would you use
pcleary is offline
post #15 of 20 Old 10-19-2010 Thread Starter
traveller
gary could you send me the photos by email ----clearypaddy@hotmail.com thanks paddy
pcleary is offline
post #16 of 20 Old 10-19-2010
Originally Posted by pcleary View Post
what would you use
This:
post #17 of 20 Old 10-23-2010
Stainless inserts, in a stainless plate, with stainless screws. Where do you see a problem?
Gary H. Lucas
post #18 of 20 Old 10-23-2010 Thread Starter
traveller
gary can you send the photos thanks paddy
pcleary is offline
post #19 of 20 Old 11-21-2010 Thread Starter
traveller
any pictures yet gary i sent you my email address in case you couldnt upload thanks paddy
pcleary is offline
post #20 of 20 Old 11-21-2010
I'm sorry, I thought I already sent them to you. Send me an email at gary.lucas@verizon.net and I'll send them right back to you.
Gary H. Lucas
Harken Traveller on a C&C 32 Kiltmadoc Gear & Maintenance 10 07-18-2010 05:47 PM
sticky traveller Bene505 Gear & Maintenance 7 07-16-2009 01:14 AM
P26 cabin top traveller dbruce85 Gear & Maintenance 2 03-27-2009 07:55 PM
Lewmar Traveller Shortman Gear & Maintenance 12 03-22-2009 07:35 AM
When to use the traveller saurav16 Learning to Sail 18 08-28-2007 05:03 PM
