Old 10-15-2010
pcleary is on a distinguished road
traveller
how do i put back the traveller on my etap 26 as i cant find any backing plate and access is impossible
Old 10-15-2010
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
So you're not the one that took it off I suppose?
Pictures would help, you need to have at least 10 post I believe to be able to post pics, try the joke thread or something to get your post count up
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 10-15-2010
QuickMick's Avatar
QuickMick is on a distinguished road
the op had had installed one on my boat right on the step into the companionway... access by crawling into the engine compartment and sticking my hand way up there. he did not use a backing plate--just long a$$ bolts--as there were many of them. you may be able to access this area, but i would caution that after i removed mine i did not reintall it as that companionway placement was a royal PITA to constantly negotiate in and out of the cabin....
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-16-2010
it just pulled off in a strong breeze
Old 10-16-2010
Can you post some pictures of the situation? Since it 'pulled off" clearly it was not well-installed in the first place..
Assuming it's an '80s Etap, not the newer raised cabin version (which does not appear to have a traveller) from the few pics I've been able to find it looks like a bridge deck location.
Can you at least access the under-seats area? It may be possible to reinforce the traveler bar with some square tube or someother.. and bolt it down at either end.. even if it means cutting out some strategically placed holes in a liner..(they can be bunged up later)
1984 Fast/Nicholson 345
Old 10-16-2010
i enclose photos of traveller position hope they help paddy
traveller-tally-001.jpg   traveller-tally-002.jpg   traveller-tally-003.jpg   traveller-tally-004.jpg   traveller-tally-005.jpg
Old 10-16-2010
It does look like you'd have access from inside the engine compartment. Does the forward end, at the companionway, open up??
Old 10-16-2010
GaryHLucas is on a distinguished road
I caught your thread this evening, and I may have an answer for you tomorrow as I am going down to my Etap 26 in the morning. I have a camera, and a See Snake with a camera and light on the end of a 3 foot flexible shaft. Also my boat was modified by the previous owner. I have a slide out cooler under the companionway step, and a door behind that which gives access to the front of the engine. So I should be able to get pictures of what is there, and how to reach it.
Unfortunately this reminds me of a friend who was an aircraft mechanic, and trying to replace the throttle cable on a Learjet. He called the factory because he was having a tough time, and they told him it was really easy to do, should only take about half an hour. Then the guy asked what was giving him trouble. He said "The damn engine is in the way!"
the response was "You didn't remove that yet?"
Gary H. Lucas
Old 10-17-2010
thanks gary a good story hope your pictures will help paddy
Old 10-17-2010
I got pictures today, but need to resize them so I can upload them
Gary H. Lucas
Harken Traveller on a C&C 32 Kiltmadoc Gear & Maintenance 10 07-18-2010 05:47 PM
sticky traveller Bene505 Gear & Maintenance 7 07-16-2009 01:14 AM
P26 cabin top traveller dbruce85 Gear & Maintenance 2 03-27-2009 07:55 PM
Lewmar Traveller Shortman Gear & Maintenance 12 03-22-2009 07:35 AM
When to use the traveller saurav16 Learning to Sail 18 08-28-2007 05:03 PM
