10-17-2010
Originally Posted by hellosailor
Rob, I'll bet that if you hit each one with a wire wheel or cutting disc, the sparks that they throw are different in size, color, and shape. Spark tests are a pretty simple way to tell metals apart, take a look on the web & I'll bet you can find pictures of what each look like. (Or compare /vs/ a new one of your choice.)
Well, I did do a search and apparently the sparks are too similar, but magnesium does catch fire, so that's something. One source said to heat the metal, then add water, if it burns down the shop then it was magnesium.
I could also take some shavings and try to burn them...zinc won't burn. Another test is electrical, but you need to immerse the part in water. Most tests seem to be chemical, using an acid or alkali..
All of which is far too complicated, so when I'm hauled out I'll just instruct the yard to drill out the anode of unknown composition.
Gene: I'm not sure how adding a more noble anode would increase the rate of decay of the least noble anode?
Rob C
