Old 10-16-2010
Livia's Avatar
Vagabond in Training
Livia is on a distinguished road
Question Backflushing
I'm doing our watermaker research for the big purchase and the concept of backflushing came up in a few threads.
After reading the Katadyn PowerSurvivor 40 manual and Ishipaco's most wonderful site on the topic, my understanding is that if you are using your watermaker every day or every other day there is no need to backflush with product water. Obviously, flushing is never a bad thing (without chlorine) so it would still be a reasonable practice - but not necessary unless you are going to use your watermaker less frequently.
Am I missing something?
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
Old 10-16-2010
Backflushing the watermaker is a good idea, even if you use it every day as it helps keep the RO membrane cleaner. But you shouldn't need to backflush it every day—once a week should be enough, provided you are using it in relatively clean conditions. Just remember that you should not flush the membrane with chlorinated water as the chlorine will damage the membrane.
Ideally, the RO watermaker should have a dedicated tank with check valves, so that water from the rest of the fresh water system can not get into it. This reduces the chances of you flushing the watermaker with chlorinated water.
Using a watermaker in silty or oily waters is really a bad idea, since both petroleum products and silt can damage the membrane. Most civilized harbors are not clean enough to run a watermaker, and you should probably close off the intake line seacock after flushing the RO membrane when in such areas.
Old 12-04-2010
foggysail is on a distinguished road
I am midway through my design/build phase. I intend to backflush after every use because I am using a BRASS pump. Could not afford the big bucks for either bronze or SS. In general, I think backflushing should be done after use anyway. But again----just my thoughts.
Foggy
Old 12-04-2010
Minnewaska will become famous soon enough
Spectra watermakers run on 12v and have an autocontroller that will backflush when necessary.
Old 12-13-2010
Livia's Avatar
I went to the manuals and the Spectra recommends backflushing on each use while the Katadyn does not (if used regularly). If you are using a very low output watermaker backflushing takes up a lot of your production water.
Old 12-14-2010
RichH's Avatar
RichH will become famous soon enough
Actual "Backflushing" of RO membranes is not that common nor all that necessary. "Forward flushing" is the preferred method using appropriate chemicals to remove debris, and to restore flow characteristics etc. The choice of prefiltration retention and surface area will diminish the need for 'backflush' of the RO membrane.
To properly backflush an RO membrane, one must remember that the transmembrane pressure to properly 'make water' is 800+ psi, and with the common 'spiral' formed membranes the normal flow is essentially from 'outside' the spiral to 'inside' the spiral and putting 800 psi in the wrong direction across the 'pack' can easily burst or break the membrane. RO membranes are 'tangential flow devices', the fluid travels across the surface of the membrane and at high pressure a portion of the fluid enters and passes through the membrane as product water. The PROPER velocity (amount) of the inlet water flowing across the outer surface of the membrane will or should keep the membrane 'clean', usually this is already in the 'design' of a prepackaged or 'skidded' system.
However, the entrance areas to the 'spirals' do in fact eventually become plugged with particles (mostly deformable 'slimes', etc. and low pressure backflushing in the 'reverse direction' across the 'upstream' side of the membrane with clean 'product water' may be of benefit to dislodge the particles that 'bridge' and plug the 'entry' to the membrane package. A better way is to 'tighten' the retention µM of the prefilters (or/and select a prefilter that has high removal efficiency) and increase their surface area to insure the correct 'delivery flow' to the membrane - prefilters are more easily 'backflushed' (not to exceed ~15 psi when backflushing) than RO membranes, but dont wait until the prefilters become plugged before backwashing!!!!!!. Typical backwashing of prefilters is done with no more than 15-20% of the 'forward' flow at 15 psid MAX. pressure, ... with HOT (160-170° max. temp.) clean product water if you can.
There are specialized chemicals for sanitization and 'cleaning'
1. sodium/potassium metabisulfite will kill/stun and keep the biological growth low inside (both sides - retentate and permeate) the membrane. Biofouling is by very 'sticky' and soft particles that can easily 'plug' an RO membrane. Metabisulfites are entered into the system by 'forward flushing' ... just add the chemical solution to a quanity of previously made input 'product water'. Severe flushing after 'pickling' is required to remove the Mbsulphites as they are not compatible with 'human consumption'.
The following are common to industry and require precise usage by chemical and safety expertise:
2. Sodium Hydroxide mixtures are used to dissolve organic fouling on the surface and partly 'into' the membrane; you essentially 'soak' the membrane in situ, then flush. Precise chemical expertise is needed to insurer the ALL the NaOH is removed before you start to use/store the product water. Sodium Hydroxide is 'lye'. A hydroxide flush is done in the 'forward' direction.
3. Peracetic acid + hydrogen peroxide mixtures. (requires severe chemical knowledge and the usage of 'indicator strips' to insure total removal when finished) Do websearch for "MinnCare". Peracetic+H202 will dissolve 'salts' entrapped in the RO membrane 'pores', plus will kill virtually 'everything' inside the system.
4. inorganic 'hard particles' .... use 'better' prefiltration - tighter and more 'efficient' and 'larger surface area' filters upstream of the RO portion.
Cautions:
Watermaker usage should be limited only to 'visibly' clear/clean input water to avoid premature plugging of the RO membranes. 'Watermakers' are not 'absolute' in retention and should NOT be used in areas of suspected high bacteria or virus, etc. concentrations: harbors, anchorages, other boats, cities, large population areas, sewage treatment plants etc. If a 'single' microorganism passes through the RO membrane it can rapidly divide/multiply in the relatively 'stagnant' water on the 'downstream' of the membrane and then begin to very rapidly produce massive colonies in the piping, tanks, your intestines, etc. RO product water from a 'watermaker' should always be further dosed with a bacteriostat - clorox or other chlorine agent, etc.
Watermakers should be routinely and periodically 'pickled' with at least potassium/sodium meta bisulphite to reduce the 'bio-burden' or 'growth' inside them.
FORWARD FLUSHING after usage is a damn good idea.
Suggestion is made to make a few gallons (~5+) of product water into a separate 'container' and when finished making your water for the day, etc. shut off the raw water inlet and suck in the ~5+ gallons to 'clean out the low and high pressure pump', the prefilters, the lines, the surface and 'some' of the 'pores' of the RO membrane .... this will dilute the bio-burden that was accumulated during water production (reduces 'metabolites'), reduce the 'salt content' of the water to protect any stainless steel, brass, etc. surfaces.
Old 12-14-2010
jrd22's Avatar
Courtney the Dancer
Livia- there was an excellent discussion about watermakers on the Pacifiic Puddlejump site last month. I learned a lot, you might want to join the Yahoo group and access the messages and read through them.
pacificpuddlejump : Pacific PuddleJump
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 12-14-2010
Rich--
EXCELLENT POST! And I screwed up, of course one cannot backflush a piston pump easily. I should have stated--flush. But because of the brass pump head, I have no choice as I see it other than to flush after each use.
I am still in the parts collection phase and design concept phase. I was able to purchase a used CodeLine 2540 pressure vessel but have not been able to fine another used one. Might need to spend more and purchase it new.
I know this is off topic but my goal is to minimize plumbing be using transducers to meters rather than pipes. MOre as I progress.
Now to check out the PuddleJump
Foggy
Old 12-14-2010
ughmo2000 is on a distinguished road
If your still undecided, check out Cruise RO watermakers.
Rich makes some nice twenty plus gallon per hour watermakers.
Tayana 37
s/v Adventure Bound
Old 12-16-2010
Livia's Avatar
Very interesting RichH. I thought backflushing meant taking product water and putting it back through the system (in the forward direction) - now I'll have to go back the manufacturers literature and see how they are using the term.
Thanks jrd22 - I'm a member the PuddleJump site but because we are at least a year off that jump I have not been following it recently. I'm heading there now to read.
