Old 10-17-2010
sailing320's Avatar
sailing320 is on a distinguished road
Clogged Head
I think I have a clog somewhere in my hose between my head and my holding tank. What is the best way to fix this issue? When I pump my head the pump arm has pressure and will not remove any water in the bowl and springs up. Marina did a pump out so I know my tank is empty. I have a Jabsco head and replaced the pump with their service kit. What should I do?
Old 10-17-2010
mitiempo's Avatar
Several possibilities. Could be the holding tank vent is clogged. Or the hose from head to holding tank is clogged.
Has the head worked after you rebuilt it? If not maybe you assembled it incorrectly.
If the hose to the holding tank is the problem the only solution is to remove the hose to clear it.
Brian
Old 10-17-2010
sailing320's Avatar
I installed the repair kit as a fix. It did not work. Could this be a vent issue?
Old 10-17-2010
mitiempo's Avatar
Yes, if the tank isn't able to vent you would have trouble pumping. Or the hose to the tank is clogged.
Brian
Old 10-17-2010
sailing320's Avatar
How do you check the vent? I have never done this? Is their something I can put done the head to clean the hose?
Old 10-17-2010
mitiempo's Avatar
To clear the vent hose remove it from the holding tank and blow through it (not with your mouth!) to see if it is clear. Or remove it from the vent end as well and flush it out on the dock. Also check the vent fitting on the boat to see if bugs have built a nest in it or something else is clogging it. Nothing put in the head will clear it. It goes from the top of the holding tank to the vent fitting which is usually on the side of the boat just under the deck edge.
Brian
Old 10-17-2010
deniseO30's Avatar
Lies about her age
Silly question, did you see the marina do the pump out? just sayin..
Old 10-18-2010
Did you replace the entire pump on the Jabsco? Or just the parts in the service kit?
As the previous posters said...it could be a holding tank vent line issue or a full holding tank issue....which can easily lead to a holding tank vent line issue.
You should rinse/flush the holding tank vent line at least once a month IMHO, especially if you're the type that leaves pumping out the holding tank until it is nearly full.
Also, which Jabsco head do you have???
Old 10-18-2010
sailing320's Avatar
Yes, I saw the pump-out. The marina pumps out my waste and flushes my holding tank 3 times every other week. Would this clean the vent? I only replaced the head with the Jabsco service kit. Also, when it happened I turned on my marcerator but nothing come out the side of the boat. It appears to be working but I only use it once a year at best.
Old 10-18-2010
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
It is not the vent.
With an empty tank you would be able to flush the contents of the loo into the tank slightly pressurising the tank even if the vent is blocked..
Keep doing it and the phrase "She's gonna blow" will enter your life.
Time for the rubber gloves, a couple of buckets and the courage to disconnect the hose from the toilet to the tank.
Clogged waste line? inthesprings General Discussion (sailing related) 22 08-09-2009 02:19 AM
Clogged seacock...please help! lowcountryking Gear & Maintenance 14 03-17-2009 01:32 PM
Holding Tank Vent Clogged? garydory28 Gear & Maintenance 7 03-06-2009 11:32 AM
Fuel line clogged? davidpm Gear & Maintenance 3 05-15-2008 12:04 AM
Clogged Marine Head mathislaw1 Gear & Maintenance 39 03-30-2007 08:18 PM
