Old 05-05-2003
GordMay is on a distinguished road
Keel Bolt Torque
C&C Specifies 250 Ft/Lbs torque for 3/4" Keel Bolt c/w 1-1/8" Nut.
Does this assume boat on the hard, sitting on keel?
Would the required torque be different for a boat afloat?
Tks,
Gord
Old 05-05-2003
DuaneIsing is on a distinguished road
Keel Bolt Torque
Gord,
Here is my opinion on your keel bolt torque question:
Whenever threaded fasteners are used to join components, the designer is trying to achieve a desired clamping force by putting the bolt (screw, etc.) in tension. Since measuring the tensile force in the bolt is difficult to do, engineers specify torque values. However, the amount of tensile force in the bolt for a given torque value varies greatly depending upon the condition/geometry/material of the threads, their cleanliness, and degree of lubrication.
To your question, if all the above factors were equal, it should not matter whether the boat is on the hard or in the water. The resultant clamping force should be the same for the same torque value. To use a different value for the torque would imply that you need a different clamping force under those two conditions and I don''t see that as logical.
Hopefully folks with real boat experience will agree.
Duane
Old 05-07-2003
lecomte38 is on a distinguished road
Keel Bolt Torque
TIGHT. as tight as you can make them with 1/2" drive sockets and a breaker bar.
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 04:36 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 03:09 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
